Temp. upgrade to my GPU. Possible issue with PSU.
Post Date: 2008-10-25
Axel Daemon View Drop Down
  Quote Axel Daemon Quote  Post ReplyReply bullet Topic: Temp. upgrade to my GPU. Possible issue with PSU.
    Posted: 25 Oct 2008 at 9:49pm
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152026
Old arse thing that was bought at the time.
I have a Geforce 7900 GT.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130362
GPU I figured I'd get.  Reason being is, I think my 7900 is partially fried, I see so many color dots on my screen if there's a black background lol.
Apparently one of the comments show that I need 26A on a 12v something?
I'm no expert at PSUs so no clue what I'm looking at.
" Minimum of a 400 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 22 Amp Amps.)" - EVGA Site
Edited by Axel Daemon - 25 Oct 2008 at 10:14pm
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 25 Oct 2008 at 10:16pm
Well I just describe it as that, what happens is that, depending on the temperature, I see color pixels on the screen (they're more noticeable on any part of the screen that's colored black).  It's sorta like dead pixels from the monitor, but it's coming from the GPU.
At 55*C there's very little, at 60*C there's alot lol.  I can't print screen it, cause it's the GPU more or less.
That's besides the point, it's time I upgraded a little bit anyway, even if I'm getting a new computer, I can make this computer have some umph to it =P
Edit: " Minimum of a 400 Watt power supply.(Minimum recommended power supply with +12 Volt current rating of 22 Amp Amps.)" - EVGA Site
Edited by Axel Daemon - 25 Oct 2008 at 10:17pm
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 25 Oct 2008 at 10:31pm
What's wrong with upgrading the GPU anyway?  Sure the purpose here was to remove the color dots.  But it's a 7900 GT... I'm upgrading to a decent 9 series GPU.....
Are you holding me back in getting a decent upgrade here?  For $70? XD;
J/k ahaha.
Edited by Axel Daemon - 25 Oct 2008 at 10:31pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Oct 2008 at 10:36pm
just go with one of the psu's listed in our config alex, start from 750w you should be ok
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 25 Oct 2008 at 10:36pm
It's a 630W;;; You're saying that's not enough?  I wanna keep the upgrade under $100 lol.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Oct 2008 at 10:42pm
the 9000s pretty much have the same PSU requirement as the 260 GTX
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 25 Oct 2008 at 10:55pm
It's more like that IS the PSU I'm using to power the 7900 GT so yeah lol.  That PSU is discontinued anyway ahaha.
And why do you go all programmer language like?  Aaaaand.  mind fixing that very last sentence?  It words out awkward.
Edited by Axel Daemon - 25 Oct 2008 at 10:55pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Oct 2008 at 11:11pm
that java I think when he copied the text the java code got copied
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Oct 2008 at 11:27pm
some sites do that
TomD View Drop Down
  Quote TomD Quote  Post ReplyReply bullet Posted: 26 Oct 2008 at 11:29am
To answer your original question, your existing PSU will run any single card out there. 630w is plenty.
The only minor issue you will have is that your PSU does not have an 8-pin power connector which is needed by the 260/280gtx and some other more recent cards. If you end up getting a card that needs an 8-pin connector, just make sure the card ships with an adaptor (most do).
Also, you don't mention what case you have, but make sure it has enough room for the card you buy. The newer cards are longer than the 7900 and may not fit in an older case.
Good luck!
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 26 Oct 2008 at 12:54pm
Every card in the Geforce 9 series is at least 9 inches long.
If you're hurting for space, get a HD4670. ~$70, ~6 inches long, and no PCI-E cables needed.
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 26 Oct 2008 at 1:30pm
Hp Pavilion a1445n.  -grabs a measuring tape and measures inside-
Yep more than enough space.
Thanks guys!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Oct 2008 at 1:34pm
good luck AD, let us know how it goes
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 26 Oct 2008 at 1:55pm
Yep yep.  Thanks again.
Actually on a small note, while the GPU interface is PCI-E 2.0 my mobo ain't it only has PCI-E x16 slot only.  (Being two years old yeah heh.)
As far as I read, the only thing this does is that the GPU's full potential isn't tapped into.
http://pclivecs.co.uk/images/Motherboard%20pencil.gif
Edited by Axel Daemon - 26 Oct 2008 at 1:58pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Oct 2008 at 1:58pm
yes I have a 8800 gts sitting on a pci-e x16 folds like a champ and I have no complaints but I don't play games with it, I'm sure you would notice the difference during games.
so you might want to think about that, if its for games.
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 14 Nov 2008 at 10:14pm
Got the GPU, installed it, cleaned the stock CPU heatsink while I'm at it.
Installed new beta drivers..... and it works!  Time to test some games and see how things go.
Only problem so far.... my calibrating program ain't kicking in! -gets previous drivers-
Since it might be because of the drivers....
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Nov 2008 at 11:19pm
nice let us know
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 14 Nov 2008 at 11:30pm
http://www.portrait.com/dtune/iqt/enu/compatibility.html
...... Something tells me it's because of the new GPU.   This won't work....
The calibration option makes the colors look REAL nice.  Guess that won't be happening anymore ahaha.
