TFC Monsta Extreme uber radiator.
Post Date: 2009-05-31
AbsiNthe View Drop Down
  Quote AbsiNthe Quote  Post ReplyReply bullet Topic: TFC Monsta Extreme uber radiator.
    Posted: 31 May 2009 at 10:55pm
Hello everybody, This is my first post so Im going to use it to introduce myself as well as to discuss the topic suggested in the title above.
I've been basically a prowler among these forums for several months..drooling..and checking back daily to see if any new customer reviews have arrived.  So I decided to finally register..I don't know why I didn't earlier..but whatever.
Anyways.. I was wondering if you guys had seen this uber radiator and What you think, as well as where in the hell you'd put it in/on your case lol.
http://www.youtube.com/watch?v=mvj1cculKn4
^See what Everybodys favorite welsh techy Trubritar says^ :D
What do you all think?
  Quote AbsiNthe Quote  Post ReplyReply bullet Posted: 31 May 2009 at 10:58pm
Ill add the specs now, got a bit overwhelmed by the big pictures :D
Dimensions: 476 X 148.6 X 104.2
Fan Spacing: 15mm
Weight: 7.7 lbs (3.5Kg)
Coolant Capacity: 1.4L
Fitting Thread: G 1/4
comes with a 3year warranty as well.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 01 Jun 2009 at 11:29am
Very low restriction, wich is amazing for its size. Not many cases easily support 140 mm rads, especilly this thick. With push pull/ and shrouds it would be 10" thick. ROFL. It is a great piece of work, but it is $$$$ and will take a little extra work and imagination to implement it. I will stay with my 4 tripple rads for a while longer.. Clap
  Quote AbsiNthe Quote  Post ReplyReply bullet Posted: 01 Jun 2009 at 3:16pm
haha yes some imagination indeed :]
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 01 Jun 2009 at 3:43pm
Get the Lian-Li/ABS Canyon full tower. It has a place to put this. O_O
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 01 Jun 2009 at 3:54pm
It won't fit those cases inside. Just the rad and one fan, no shrouds, it need 6" of depth. It is a no go. lol
  Quote AbsiNthe Quote  Post ReplyReply bullet Posted: 01 Jun 2009 at 6:33pm
:O? hmm..if you cant fit it in the ABS canyon where can you fit it? lol youd need like a foot of extra tubing so you could put it on a shelf next to your pc.
Edited by AbsiNthe - 01 Jun 2009 at 6:34pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 01 Jun 2009 at 6:48pm
There are a lot of cases it will fit, Tj07, pinacle 24, lian li 2010, ascension, ect. lol But, it will take mods to make them work, except maybe the Tj07, the MM cases would have to be custom ordered, lian li 2010 woud take a bit of modifying also.
