Thermal CompoundPost Date: 2009-02-06 |
| Author | |
Dsnewb210
Joined: 01 Oct 2008 Online Status: Offline Posts: 972 |
Topic: Thermal CompoundPosted: 06 Feb 2009 at 1:44am |
Will you void the warranty on your gpus if you add your own thermal compound?
Also what is the best thermal compound?
Would you notice a big difference over the cheap stuff thats already applied?
Im thinking Artic MX-2 or Artic Silver..
<8) slunK parade
Joined: 20 Jan 2009 Online Status: Offline Posts: 798 |
Posted: 06 Feb 2009 at 2:46am |
probly no real gain, unless the pre applied stuff is done badly
Posted: 06 Feb 2009 at 3:10am |
I'm sure the warranty will be null. I think CPU would be OK but GPU is different.
as SP says, unless its not done right you will see no real gain. |
Dsnewb210
Posted: 06 Feb 2009 at 11:21am |
Im talking about the gpus, Ive been reading about alot of people changing out the thermal paste and having temps drop 3-7c. |
Lnguyen
Digital Storm Engineering
Joined: 08 Oct 2008 Online Status: Offline Posts: 22 |
Posted: 07 Feb 2009 at 12:28am |
not worth it, wont make a difference
