Thoughts on tower for cintq
Post Date: 2019-08-11
Oz_leon101 View Drop Down
  Quote Oz_leon101 Quote  Post ReplyReply bullet Topic: Thoughts on tower for cintq
    Posted: 11 Aug 2019 at 9:17pm
2500 (Not Including Cintq Monitor)
Want this computer to last me a good while but also handle playing at max graphics for most games Like Final fantasy XIV, Destiny 2, Borderlands 3 and more. Also be able to handle my 3d modeling program with ease and not go crazy when I have to much on the screen.
3D Modeling in Zbrush, Maya, 3DsMax. Game Development; Unity and Unreal engine. Gaming; Final fantasy XIV, Boderlands, and more
Being able to handle 2 normal monitors and 1 cintiq monitor
Saved Ticket #:
2511067
Processor: Intel Core i7-9700K (4.9 GHz Turbo) (8-Core) 3.6 GHz
Motherboard: MSI MPG Z390 GAMING PLUS (Intel Z390 Chipset) (Up to 2x PCI-E Devices) (No SLI Support)
Power Supply: 600W Digital Storm Performance Series (Supports up to an NVIDIA RTX 2070 GPU)
Optical Drive: - No Thanks
Graphics Card(s): 1x GeForce GTX 1650 4GB
Extreme Cooling: H20: Stage 1: Digital Storm Vortex Liquid CPU Cooler (Single Fan) (Fully Sealed + No Maintenance)
Airflow Control: - No Thanks
Mouse Pad: - No Thanks
Display: ASUS 24 inch VP248QG (75Hz Refresh) (1ms Response) (1920x1080) <br><strong></strong>
Branded Gear: - No Thanks
  Quote Cretae Quote  Post ReplyReply bullet Posted: 12 Aug 2019 at 4:15am
The build you have chosen isn't close to serving the needs you lay out.
This suggestion fits the bill pretty closely with the $2500 budget:
Config ID 2524939 (At the main page, select "Load Config" at the upper right and copy and paste this #)
With the $200 discount in effect now, it comes in at $2607. From what you said, I left off the monitor.
You get:
-Upgrade to the i9 9900K for the 16 threds that will be of great value to you for 3D rendering.
-32 GB of RAM for 3D help
-850W Corsair power supply with a 5 year warranty to provide what you'll need for future upgrades.
-A Samsung 970 PRO NVMe SSD for a 5x faster primary drive, and a 5 year warranty.
-A much more powerful RTX 2060 which is the best choice for maxing graphics in the games you play at 1080p at this budget.
-Corsair H 100 Pro all-in-one cooler to allow for safely overclocking yout CPU for top performance, and another one of those nifty 5 year warranties.
-FREE internal lighting strip for some extra bling if you want.
-Overclock the CPU safely.
The best way to bring this build down under $2500 or make room for the monitor you chose, would be to choose a Lumos or even a Lynx case.
Next best would be to cut back to 16 GB of RAM which you could easily upgrade at a later date. Any other downgrade would either hurt your performance too much, or leave you vulnerable to a lesser warranty.
Hope it helps.
  Quote Oz_leon101 Quote  Post ReplyReply bullet Posted: 13 Aug 2019 at 8:17pm
This is Awesome! Im look into something Like this more. Im always worried if what im getting is good but this seems to fit the bill perfectly. Im on if it goes over budget a little. I just want to make sure this will last especially for what im putting down for money wise! Thanks for the help!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 14 Aug 2019 at 3:21am
DS rigs that are not just very basic are well known for lasting a very long time. These parts are cutting edge at this time, and expected by their makers' warranties to last a very long time. You're in very good shape with that set-up!
