to overclock or not to overclock
Post Date: 2018-03-28
fparamo1979 View Drop Down
  Quote fparamo1979 Quote  Post ReplyReply bullet Topic: to overclock or not to overclock
    Posted: 28 Mar 2018 at 3:04pm
I have never overclocked any of my computer and was thinking of having my new ds system overclocked for me. How much life can i expect from my cpu and is it really worth it?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 28 Mar 2018 at 3:55pm
Depends what cpu you’re ordering, the cooling etc.
If you’re ordering the 8700k then overclocking isn’t needed for gaming.     It Turbos to 4.7 on single core which is very good for gaming.
If you do have DS overclock then the cpu will be fine with no loss of life expectancy.
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 29 Mar 2018 at 12:02pm
If you aren't going to overclock, save your money on a K edition.  Many, many games utilize multi-core and multi-threaded cpu's.  Now most don't really use more than 3-4... and even those are a small percentage.
But if you're going to buy a K edition 7000 series or 8000 series, buy a good cooler and have fun hitting 5ghz with literally no effort at all.
DS does very modest overclocks from what I've learned over the years.  Life expectancy decreases are really non-existent.  And if you CPU does die early, it won't be from DS's overclock.  It'll be from crappy silicon lottery.  I'd probably just save my money, and either do the OC myself as it's so easy there's video's five year old overclocking 7000/8000 series cpu's to 5ghz.  Just make sure you have a decent noctua/aio/custom loop to cool it.
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
  Quote hoserator Quote  Post ReplyReply bullet Posted: 30 Mar 2018 at 1:40am
Hi Meller, nice to see you around. Awesome
  Quote Meller Quote  Post ReplyReply bullet Posted: 31 Mar 2018 at 8:30pm
Hello, Hoserator.
You never saw me.
Custom PC
Ryzen 9 5950X
128GB DDR4 3600mhz
  Quote hoserator Quote  Post ReplyReply bullet Posted: 01 Apr 2018 at 2:57am
"I know nothing and deny everything" DST4ME Big%20Smile
  Quote Cretae Quote  Post ReplyReply bullet Posted: 02 Apr 2018 at 5:47am
This page was generated in 9.863281E-02 seconds.
