Top fan on the Trooper
Post Date: 2015-02-12
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Topic: Top fan on the Trooper
    Posted: 12 Feb 2015 at 6:44am
So not sure how long its been not working but it doesn't seem to want to start up, i mean it will move a little but thats about it. It doesn't seem to be hindering performance but do you think i should have it replaced or not worry about it?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 7:07am
Hi Arkansas....  The top 200mm fan on my 600T was off for a month or so while waiting for a new fan control.  I could've easily hooked it up but didn't, kind of a testing type thing, and I didn't see any difference in temps.    My cpu cooler, the A70 blew the heat out the back and the video card exited out the back.
My opinion is to change it, but mainly because its there.  Hahaha
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 7:11am
If i do decide to change it, i'll probably wind up changing all the fans to maybe Noctua or Cougar fans just in case the other three fans bite the dust which probably won't happen anytime soon but better safe than sorry
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 7:15am
Sounds like a plan.  Big%20Smile      Fans are pretty reliable, but tweaking the build is always fun.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 7:18am
The fun part will be trying disconnect the fans that are already in there. DS cable management is so superb
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 7:30am
 LOL     You'll never get it looking the same.
Edited by bprat22 - 12 Feb 2015 at 7:31am
Pacesetter View Drop Down
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 8:23am
You mentioned " it will move a little but that's about it".
You might try using a 'pin point' oiler to add a drop of oil to the fan shaft where it goes through the housing.
I use DeoxIT X10S precision instrument oil.
http://store.caig.com/s.nl/sc.2/category.728/.f
Vanquish II Ultimate.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 8:37am
Arkansas, just thinking after Pacesetter's comment of it moving a little..... Your Storm Trooper case has a front fan control.    Behind the right cover are there fan headers hanging down that the top and front fans hook to?  If so, try swapping the fans and the connectors they use to see if the fan control itself is going bad.   A bad fan header from the controller might cause it to attempt to start and then doesn't.
Edited by bprat22 - 12 Feb 2015 at 8:38am
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 1:31pm
I dunno i'll have to check later, if i replace the fans i'll probably just hook them to the Mobo and let the mobo handle them.
Also i noticed my motherboard Sabertooth z77 has the option for 4 PWM fans so i might go that route
One more thing i'm new to CFM but does the rear fan need to be higher or lower than the front fans?
Edited by ArkansasWoman777 - 12 Feb 2015 at 2:17pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 3:41pm
Nope.   The rear fan doesn't have to meet any particular specs.   If the front fans have more cfm, which they will, any extra airflow goes out the rear and top open grills, like below the video card.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 3:42pm
Ok gotcha, thanks Bprat
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Feb 2015 at 3:44pm
Always a pleasure.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 7:08am
So i found the fan cable to the top fan along with the rear cable while dusting out my pc today, both are bundled together but i'm having an issue unhooking the fan extension cable to the end of the fans cable.
Is there any easy way to do this?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 7:19am
They usually connect in one of 3 ways....  Just stab on with no locking...or, a small plastic locking tab needs to be pushed in with your nail or a pen... or,  the connector has two locking tabs on the end that you just squeeze together as you pull it apart.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 7:28am
Such a shame, i cut my nails
I think its either of the last two that you mentioned. I might take it to a computer shop along with some new fans and have them replace it for me.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 7:35am
I think the fans just push on.   Just give it a tug.  Hahaha
The LED lead might lock, but I'm not sure.
I think you have 3 types of connectors from the fan control, the smaller led fan connector, maybe 2 of those,  a little larger fan connector, maybe 4 or 5,  and the larger molex four pin power connector.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 7:36am
I also just cut my nails, otherwise,  I'd pop over.  LOL
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 7:37am
be a long drive
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 7:43am
My Geo Prizm gets great mileage and I once drove from Oklahoma to Rhode island in 36 hours.     Of course, I was much younger then..   Big%20Smile
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 7:44am
Big%20Smile
36hrs..your nuts
Edited by ArkansasWoman777 - 13 Mar 2015 at 7:44am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 7:45am
I've been told that.  HahahaBig%20Smile
  Quote Snaike Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 10:24am
Please, for the love of all that's holy and good, tell me the 36hour trip wasn't in the Geo
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 10:35am
(My Geo Prizm gets great mileage and I once drove from Oklahoma to Rhode island in 36 hours) So i assume it was....lol unless he had a different car at the time
Edited by ArkansasWoman777 - 13 Mar 2015 at 10:35am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 11:08am
Nope, no Geo then.  It was a '65 Plymouth 383 Satellite.  Crappy mileage, but back then gas was cheap.  Big%20Smile  The ride with its heavy suspension almost caused me to have no kids.  Hahaha
Fun times.  Drooling
Just an interesting nugget.... gas back then was about .30 a gallon.    Cry
Edited by bprat22 - 13 Mar 2015 at 11:30am
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 12:37pm
Nope, no Geo then.  It was a '65 Plymouth 383 Satellite.  Crappy mileage, but back then gas was cheap.  Big%20Smile  The ride with its heavy suspension almost caused me to have no kids.  Hahaha  Fun times.  DroolingJust an interesting nugget.... gas back then was about .30 a gallon.    Cry
dang i just looked up a picture of a 65' plymouth and omg its soo
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 1:34pm
Yeah, that was a nice ride.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 3:14pm
Definitely! Its a shame such beauties cost a small fortune to own anymore, unless you just use them as garage ornaments (like my Cutlass, Oops).
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 3:35pm
What year Cutlass ?
Cars had personality back then.
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 4:55pm
Since this is a post about fans; The fans were great back in the day!!
'71 road runner - red with white convertible top and white leather interior and a 426 HEMI
'72 boss Torino with a 429 - painted to look like starsky and hutch car.
On a Sunday drive I saw a Henry J sitting in a farmer's field. I asked what he's ask for it and he said haul it off. OMG I was elated! Turned it into a roadster with a chevy 327/396HP and hurst 4 speed with a mystery shifter. Smoked glass ordered from Ca. 27 coats of transparent blue paint and 6 clear coats. You looked into the paint, not at it.
Those were the days!!
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 6:00pm
What year Cutlass ?
69 Supreme!
I also have a 79 Supreme, but it needs an entirely new engine. Its the original, plus its the 260 which I was never a fan of compared to the 350. It could also use a paint job. Its also about 1000 miles away Frustrated
I always enjoyed the Supremes, it was a nice middle ground since I could never afford the other "better known" muscle cars. Big%20Smile
  Quote oldlady RPGer Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 8:11pm
How funny. I was just listening to Radar Love while loading more games.
Never should have sold my "72" Torino.    Hubby says the same about his "55" Bel Air. Who knew they would be off the charts?
Now for a little "Rocky Mountain High".
  Quote oldlady RPGer Quote  Post ReplyReply bullet Posted: 13 Mar 2015 at 8:13pm
And they had gas wars!!!! I remember 25 cents a gallon. Of course making 50 cents an hour also when working summer jobs.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Mar 2015 at 8:58am
We could make a thread just on cars.  Strong
All those cars, the Road runners, especially the burnt orange  , the Torino and the Cutlass were all ..had to stop and look.. as they went by.
Just to stay on topic as Pacesetter reminded us.... they all had fans in them..  Fans are a good thing.  Hahaha
Sorry we highjacked it, Arkansas..  Big%20Smile
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 14 Mar 2015 at 9:04am
Hey, computers have fans, cars have fans.. anymore both use plastic fans.. its sort of similar? Big%20Smile
But I'll stop the derailment now. Cool
Let us know how the fan situation turns out if you get a chance!
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 14 Mar 2015 at 10:56am
Lmao its fine Bprat
I'll let y'all know how the fan situation turns out
