Triple Monitor Display Build?
Post Date: 2012-03-13
Astrotechnics View Drop Down
  Quote Astrotechnics Quote  Post ReplyReply bullet Topic: Triple Monitor Display Build?
    Posted: 13 Mar 2012 at 5:29pm
Budget is $10,000 give or take a few.
I'm going to be using it for BF3, Skyrim, rendering videos in Sony Vegas Pro 10, and a few moer stuff.
I prefer liquid cooling.
Which is better? The HAF X 942 or Hailstorm Chassis.
Aka View Drop Down
  Quote Aka Quote  Post ReplyReply bullet Posted: 13 Mar 2012 at 7:41pm
ur gpu power is based on the monitors resolution, its the most important thing.
the higher the resolution the more vram u need. first things first, find out wat the native resolution is, to the monitor(s) u'll b gaming on, man 10k on a system u can cut tht in half and wouldn't notice the difference in gaming performance fyi
btw welcome to DS Awesome
  Quote Astrotechnics Quote  Post ReplyReply bullet Posted: 14 Mar 2012 at 6:33am
Originally posted by Aka
ur gpu power is based on the monitors resolution, its the most important thing.the higher the resolution the more vram u need. first things first, find out wat the native resolution is, to the monitor(s) u'll b gaming on, man 10k on a system u can cut tht in half and wouldn't notice the difference in gaming performance fyibtw welcome to DS Awesome
1920x1080 per monitor.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Mar 2012 at 7:19am
Hi Astrotechnics.....We already discussed this under your other post..."Very well Rounded PC".
It's about the same, except you mentioned water cooling.  Do you mean the H100 closed loop type, or true water cooling as in Stage 6 with cpu and gpu's with water blocks?
For air cooling and H100 the HafX is tops.  For stage 6 cooling the Hailstorm , 800D, would be best.
Keep in mind we are real close, supposedly, of Nivida's new gpu's being released.
Avelict View Drop Down
  Quote Avelict Quote  Post ReplyReply bullet Posted: 14 Mar 2012 at 7:33am
So if you don't feel like waiting for NVidia (which isn't too far away). Here is a build that will support triple monitor for about half your budget.
Build # 665025
Price: $5,334
C
hassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X
Hard Drive Set 1: Operating System: 1x (240GB Solid State (By: Corsair) (Model: Force GT Series CSSD-F240GBGT-BK) (SATA 6Gbps)
Video Card: 2x CrossFire Dual (ATI Radeon HD 7970 3GB)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards & Chipset
Exclusive T-Shirt: Digital Storm T-Shirt - Black (Large)
Warranty: Life-time Expert Customer Care with 6 Year Limited Warranty
