Triple Monitor Gaming Rig - Advice
Post Date: 2014-06-14
Arterial View Drop Down
  Quote Arterial Quote  Post ReplyReply bullet Topic: Triple Monitor Gaming Rig - Advice
    Posted: 14 Jun 2014 at 5:36pm
Hey Everyone,
Im looking at getting a new gaming rig, and historically I've built my own, but I've decided that I'll spend some extra money to have someone reputable do it for me. I've filled out my config advice below, and I'd love any input you folks can provide.
Thanks,
$3000ish
I generally play MMO's, with the occasional shooter and I'm a fiend for steam sales. I want to be able to run 5760x1080 on Wildstar and if I decide to boot up some BF4 I'd like it to perform well at this resolution if possible
Gaming, MMO's, Occasional Shooter
I would like it to run to run quiet and have positive case pressure to keep dust out.
Saved Ticket #: Build #1009037
[B]re critique my build please :) Upped my budget to 3k and made a few changes. Let me know what you think![/B]
Edited by Arterial - 10 Jul 2014 at 9:00pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Jun 2014 at 3:05am
Hi Arterial.... Welcome to the forums.    That's a real nice build for surround monitoring but a couple of changes I'd recommend.
I'd go with the Coridium case, the Corsair 450D, for a little larger case with better airflow with 2x 140mm front fans.   The Virtue will work, so your choice.
The Z97M- plus mobo doesn't allow sli.   Change to the Gryphon.
I'd also up the psu to 850watt. Testers recommend 800watt minimum.
If the changes stretch the budget, go with 8Gb ram. Really all you need for gaming.
Good luck.
Edited by bprat22 - 15 Jun 2014 at 3:55am
  Quote Arterial Quote  Post ReplyReply bullet Posted: 15 Jun 2014 at 5:56am
Thanks bprat22 for the feedback.
I've updated my build (993708) to reflect those changes.
Should I consider the r9 290x SLI? I wish I were more up-to-speed on the current state of affairs for AMD (Drivers, feature support, etc)
Also another thought came to mind, should I wait on the Nvidia 800 series? If I wait until the end of june for Devils Canyon anyway, i'd imagine we'd be closing in on a release announcement.
Thanks,
Edited by Arterial - 15 Jun 2014 at 6:03am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Jun 2014 at 6:20am
Until the 800 arrives it's tough to compare. Chances are the new 800s will be a big step up but I'm not sure of release date. Always better coming along.
The 290x is comparable to the gtx 780ti, so yes, the Crossfire 2x 290x beats the sli 780 by a good margin plus has more vram, 3gb vs 4gb. I tend to stick with Nvidia from past driver issues, etc with AMD, but that might be a thing of the past.
290x is good bang for the buck.
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 15 Jun 2014 at 11:01am
With the mobo change and PSU upgrade, it looks like a solid build! The CrossFire 290X will definitely perform better than two 780's in SLI. The added VRAM is also a major plus.
Edited by Nav - 15 Jun 2014 at 2:36pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Jun 2014 at 1:43pm
AMD with their recent performance and pricing is making it tough to ignore them like I use to.
  Quote Arterial Quote  Post ReplyReply bullet Posted: 15 Jun 2014 at 5:24pm
Yea, i'm conflicted between strong driver support and features like Shadow Play and Game Stream (even tho I'll rarely use them, I MAY want to) vs the raw performance of the 290x's. Its tough.
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 15 Jun 2014 at 6:20pm
Definitely a tough choice... can't go wrong either way though!
  Quote Arterial Quote  Post ReplyReply bullet Posted: 16 Jun 2014 at 10:24am
Good to hear that you folks approve. I'll probably sit on it for a couple weeks to see if I hear anything about the 800 series and then put in an order!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 16 Jun 2014 at 11:31am
Let us know which way you go. StrongBig%20Smile
  Quote Arterial Quote  Post ReplyReply bullet Posted: 16 Jun 2014 at 2:05pm
Will do! Thanks for the help.
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 17 Jun 2014 at 12:15pm
Looks like a solid build whichever way you go on the graphics. As far as I have read the 290x's will out perform the 780 Tis by about 5% in Crossfire/SLI at 4K resolutions (for with 1080Px3 would count).
  Quote Arterial Quote  Post ReplyReply bullet Posted: 18 Jun 2014 at 11:43am
Yea, I'm definitely leaning towards the 290x's. I figure if I want a feature like shadowplay, i'll just go spend $100 on a capture card. Not worth gimping the setup for it.
  Quote Arterial Quote  Post ReplyReply bullet Posted: 10 Jul 2014 at 9:06pm
Rebuilt based on updated budget. Please critique!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 11 Jul 2014 at 2:54am
Looks like an excellent build.   The 450d case and sli 290x were good changes from the original.   Go for it.
nskojo View Drop Down
  Quote nskojo Quote  Post ReplyReply bullet Posted: 11 Jul 2014 at 7:31am
Good luck.
You are it can't do SLI? Z97M plus mobo allows you to choose SLI in config
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 11 Jul 2014 at 7:39am
His revised build, the 1009037, has the Gryphon mobo for sli, but i was mistaken,  this is a crossfire build.
The configurator does allow you to pick sli video card setup with a non-sli mobo, but it really isn't compatible.    The configurator doesn't catch it and DS would call the customer to correct it.  Big%20Smile
Edited by bprat22 - 11 Jul 2014 at 7:58am
  Quote nskojo Quote  Post ReplyReply bullet Posted: 11 Jul 2014 at 8:00am
Gotcha
Edited by nskojo - 11 Jul 2014 at 8:01am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 11 Jul 2014 at 8:12am
It can get confusing.  Hahaha
  Quote Arterial Quote  Post ReplyReply bullet Posted: 11 Jul 2014 at 3:08pm
Order Placed! Thanks friends.
An FYI, with the 290x's in CF, I had to upgrade to the 1050w PSU.
I'm stoked, thanks again for the help.
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 11 Jul 2014 at 3:10pm
Should be one heck of a rig!
  Quote Snaike Quote  Post ReplyReply bullet Posted: 11 Jul 2014 at 11:58pm
Look at that!  There's a really cool banner under your name.
Welcome to the DS family, glad to have you around...  Enjoy your new slice of heaven.
  Quote Arterial Quote  Post ReplyReply bullet Posted: 12 Jul 2014 at 6:24am
Glad to be part of the family. Now i need to find a good IPS, slim bezel, vesa compatible monitor to buy 3 of. I was thinking 22"-24". Any suggestions?
Edited by Arterial - 12 Jul 2014 at 6:24am
  Quote Snaike Quote  Post ReplyReply bullet Posted: 12 Jul 2014 at 6:41am
What's your budget on the monitors?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Jul 2014 at 7:13am
I have a Dell UltraSharp IPS monitor from 3 years ago, the u2311h, and love it.  Great colors and contrast.  Liking my Dell IPS, they also have the Dell U2414H, a IPS with Vesa mount.  About $230 each on Amazon.    Something to check out. Big%20Smile
  Quote Arterial Quote  Post ReplyReply bullet Posted: 12 Jul 2014 at 8:21am
I'd like to stick to ~$200 per
Edited by Arterial - 12 Jul 2014 at 8:22am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Jul 2014 at 8:50am
I would go to Amazon for example and search IPS monitors.  They have some Asus for well under $200.  I don't know the monitor's  reputations but its a good place to start.
Maybe others can chime in with their suggestions.
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 12 Jul 2014 at 3:38pm
You should be aware that at least some IPS monitors suffer from significant input lag. That is time it takes to process before it is displayed. That lag can be important in gaming.
Edited by danjw1 - 12 Jul 2014 at 3:39pm
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 13 Jul 2014 at 5:06am
I recommend my Asus Vh238h, while its not an IPS monitor its a pretty darn good monitor in my eyes
