upgrade my sound card
Post Date: 2010-05-21
Tboy72 View Drop Down
  Quote Tboy72 Quote  Post ReplyReply bullet Topic: upgrade my sound card
    Posted: 21 May 2010 at 5:18am
I recently purchased a PC from Digital Storm and now would like to upgrade my sound card to a 5.1 card. I don't know which card I should get.
Can anyone point me to a decent card for my system?
Digital Storm Desktop 209825 1
Chassis Model: Special Deal Hot Seller - Cooler Master CM Storm Sniper
Trim Accents: - Not Available
Video Card(s): 1x NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology)
H20 Tube Color: - Not Available
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
Enhancements: - Not Available
Chassis Mods: - Not Available
CPU Boost: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade)
Graphics Boost: - Not Available
Memory Boost: - Not Available
OS Boost: - Not Available
Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based
Thanks.
Core i7 930 3.8GHz OC
12 GB DDR3 1600MHz Corsair Dominator
SanDisk Extreme Pro SSD
GeForce GTX 760
Noctua Dual 120mm High Performace Cooler
Creative Sound Blaster Z SBX S card
  Quote Alex Quote  Post ReplyReply bullet Posted: 21 May 2010 at 1:21pm
The new line by Creative is great. They have a few options based on what budget you have.
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 21 May 2010 at 6:25pm
My budget is anywhere from 50.00-150.00. I guess my biggest question is which one to buy for my system. I want to be able to run a 5.1 surround sound system. It doesn't have to be top of the line, but not cheap either.
I have a pair of surround sound gaming headphones from Tritton. I think they are Tritton Ax PC Pro, 5.1 surround sound. I would be using them most of the time. Eventually I am getting external speakers as well. Mainly for playing music and gaming.
I see the cards on sites like Newegg, but I don't know which ones will work with my MOBO.
GeForce GTX 760
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 21 May 2010 at 6:30pm
Will this one work in my system?
http://us.store.creative.com/Sound-Blaster-XFi-Extreme-Audio/M/B000IZC0GO.htm
GeForce GTX 760
  Quote Alex Quote  Post ReplyReply bullet Posted: 21 May 2010 at 11:45pm
Yes it should, but make sure you have a regular 'PCI-SLOT' available and northing is in the way of it. If you don't, your motherboard may have an empty 'PCI-EXPRESS' slot and your sound card can fit into either the short or long lanes.
SemperFuzz View Drop Down
  Quote SemperFuzz Quote  Post ReplyReply bullet Posted: 22 May 2010 at 1:37pm
I have the Omega HT Claro Plus + and love it.  I had lots of problems with Creative and i used there high end models to include the Fatality line.  No problems with Omega ever when gaming now.  175 at newegg
  Quote Cretae Quote  Post ReplyReply bullet Posted: 22 May 2010 at 1:51pm
I went to your site reference, and the reviews mentioned issues with Win 7 compatibility. For any add-ons go here: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Not sure you know that card is not best for gaming, either. That same site you refed has a " compare the cards" link a few spaces down. DK anything about the Omega, but it's a little over budget? However, if a Brother Marine sez it's good, take it to the bank.  Evil%20Smile
 That's Cpl Cretae to you, SemperFuzz, and BTW, nice picture of my Daddy!  Smile
Edited by Cretae - 22 May 2010 at 1:52pm
Coolermaster Storm Sniper
Intel Core i7 930 3.8GHz OC
EVGA X58 LE
6GB DDR3 1600Mhz Ram
750W Corsair
1TB HDD
1x ATI RadeonHD 5870 1GB
Noctua Dual 120mm
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 23 May 2010 at 12:52am
Would this card be better for gaming?
http://us.store.creative.com/Sound-Blaster-XFi-XtremeGamer/M/B000J1F1BI.htm
If it is possible, I would like to keep my budget at around 100.00. That would be ideal.
I found a driver for this card for windows 7. This is the link:
http://support.creative.com/Downloads/searchdownloads.aspx?filename=SBXF_PCDRV_LB_2_18_0013.exe
This card seems to have good reviews, and fits my budget well. This should work with my system right?
The cards at Omega are a little too much money.
Edited by Tboy72 - 23 May 2010 at 1:07am
GeForce GTX 760
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 23 May 2010 at 1:27am
I never changed the sound cards on a system before. I did swap out video cards and hard drives before, so I kind of know what I am doing.
I just basically pop the sound card in a PCI slot, and install the drivers right?
My system currently uses integrated motherboard audio. When I pop the new sound card in, what happens to that? I would imagine I just change the default audio to the new card in the settings, and leave the integrated audio alone?
You have to excuse me, I never really messed with actually installing too much of the hardware. Just ram, and video cards, and hard drives.  Its time I learn though.
Edited by Tboy72 - 23 May 2010 at 1:28am
GeForce GTX 760
  Quote Cretae Quote  Post ReplyReply bullet Posted: 23 May 2010 at 8:52am
Creative says it's better for gaming, and I expect they know their products best. Installing a sound card is the same as a gpu, except goes in easier IMO. I have done several, but none with on-board audio even present, let alone enabled. since just about every mobo for several years has it, tho, I'm sure it's addressed in your instructions. I would guess step one would be to disable onboard sound in the BIOS before anything else, but that's a pure guess. If you want a preview, you probably could get full instructions from the Creative web site.
Anyone else like to chime in with some real intel? SemperFuzz?
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
  Quote Alex Quote  Post ReplyReply bullet Posted: 23 May 2010 at 1:46pm
Yes, just put the sound card in, then go into your BIOS and disable the onboard audio.
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 23 May 2010 at 3:47pm
okay. I'll give that a try. So I install the drivers for the new sound card after I go into the bios and disable the onboard audio?
GeForce GTX 760
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 23 May 2010 at 4:15pm
I just ordered it from Newegg, its going to take 3 days to get here. Probably wed, or thursday. I'll post back with any questions.
GeForce GTX 760
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 23 May 2010 at 4:17pm
if anyone knows of any decent 5.1 or 7.1 speakers for around 100.00-130.00, I'd appreciate the input.
So far, I have the Tritton 5.1 surround sound headset, AX PC pro.
One quick question, It's been a while, but F2 takes you into the bios right? Or is it F11?
Edited by Tboy72 - 23 May 2010 at 4:19pm
GeForce GTX 760
  Quote Cretae Quote  Post ReplyReply bullet Posted: 23 May 2010 at 4:54pm
I would definitely disable the onboard audio before I installed a driver that might conflict. I'm sure your instructions will tell you step by step.
For the EVGA LE, you press DELete to go into the bios. I'm excited for you! Heart Good luck.
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
Alci View Drop Down
  Quote Alci Quote  Post ReplyReply bullet Posted: 24 May 2010 at 3:11pm
Out of curiousity what was wrong with the onboard 5.1 sound? I have the same motherboard as you and my 5.1 onboard sound is pretty good (that's after I set it up correctly).
I'm certainly no where near being good with computers, but I don't see the point in buying a good sound card and bargain speakers. I researched for like 2 weeks trying to find good 5.1 speakers and couldnt find anything cheaper than $377. This is crazy but what can you do? I settled on the logitech 5500 set from amazon and the sound is pretty good with the onboard sound.  Don't go cheap on the speakers imo. Save up if you have to. Good luck.
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 24 May 2010 at 5:13pm
I don't plan on using the external speakers very often, and not so much for gaming. I use the Tritton AX PC Pro 5.1 surround sound headset, which is certainly not a bargain headset. Check out Tritton.com.
I am pretty certain the onboard sound card on my system is not 5.1. It's just 2.1, and it sounds okay, but is not true surround. I'm spinning my wheels with the Tritton surround sound headset. For what I spent on them, I want a decent sound card.
GeForce GTX 760
  Quote Cretae Quote  Post ReplyReply bullet Posted: 24 May 2010 at 7:12pm
Actually, it's 7.1. Perhaps Alci would care to share his intel on "setting up correctly" with us Noobs. I've never had on board audio before, but right now, I sometimes have more surround than I want.
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 24 May 2010 at 8:02pm
Okay, so the integrated Motherboard audio that came with my system is 7.1 surround? I thought it is just a basic 2.1, nothing special. I was told by a rep at Tritton that I would need a 5.1 sound card to enjoy true surround with my headset.
Either way, I ordered the Creative 7.1 24 bit 96 KHz PCI interface Sound Blaster X-Fi Xtreme Gamer card, and I bet I'm going to love it.
GeForce GTX 760
  Quote Cretae Quote  Post ReplyReply bullet Posted: 24 May 2010 at 8:21pm
Common wisdom around here is that good headphones will benefit from a sound card. I think you made a good choice.
Just out of curiosity, do your surround 'phones have mutiple plugs for the various outputs on a surround capable mobo/soundcard, or just one RCA jack? I don't know how they work at all, but I have 5.1 speakers, and they all have their own outputs they plug into, both on the SB Audigy I used to use, and now on the LE mobo.
Just guessing if you plug into the headphone jack on the front panel of the Sniper, all you get is stereo?
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 24 May 2010 at 10:02pm
They plug in via USB. They have an inline audio controller that is basically is about the size of a deck of cards and you can adjust the audio settings such as center, surround, subwoofer, front, center speakers. The headset has 8 speakers in it. Four on each side. They have a removable microphone that plugs into the left side of the headset. The audio controller also has a mute button for the mic.
Heres the link for the model I have, you can see for yourself how they work. I can tell you that even with the integrated audio I am using now, I found myself turning around while playing Battlefield 2 because of the footsteps I hear. They are incredible, worth every penny.
GeForce GTX 760
  Quote Cretae Quote  Post ReplyReply bullet Posted: 25 May 2010 at 12:20am
They are very kewl. Do soundcards come w/usb ports, now?
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 25 May 2010 at 5:36am
Not that I'm aware of. Mine doesn't. I'm not sure how it all works using USB as the input, but it does. I think the secret is the in line controller.
GeForce GTX 760
Alci View Drop Down
  Quote Alci Quote  Post ReplyReply bullet Posted: 25 May 2010 at 8:14am
My mistake Tboy72. I thought you were looking for 5.1 speakers in the $100-$130 price range in addition to your intended sound card purchase which made me ask whether or not the onboard sound would be good enough. I didn't catch that you had a headset too.
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 27 May 2010 at 6:05pm
okay, so I just got my new sound card, and I know I need to go into the BIOS to disable the integrated inboard high definition audio that came with the EVGA X58 LE Edition SLI. I went into the BIOS and under Integrated Peripherals, I see "High Definition Audio" which is what I'm assuming I have to disable. I also see something called TI 1394 Setting, which is currently enabled. What is TI 1394, and do I leave it enabled or do I disable it as well?
GeForce GTX 760
  Quote Cretae Quote  Post ReplyReply bullet Posted: 27 May 2010 at 10:14pm
Over my head by a mile. But lets not forget you have free lifetime support from DS. Post in "Technical Assistance" or call. I'm guessing the forum is gonna be a little sparse this weekend. Don't know where you are, but DS is in CA, and they work 9-5 as far as I know.
My best GUESS is that TI 1394 refers to Firewire support which our LE's have. Nothing to do with your sound. Don't your instructions give you any guidance?
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
  Quote Alex Quote  Post ReplyReply bullet Posted: 27 May 2010 at 10:17pm
Sorry for the late reply, we've been busy with customers calling in and such.
Disabled only the "High Definition Audio" item. Then boot into windows and install the sound driver after you installed the sound card into your computer. If a device manager thing pops up within Windows asking to search and install drivers, cancel that and use the supplied driver CD or download the latest driver from Creative's website.
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 28 May 2010 at 12:16am
Okay, let me get this straight. I disable the high definition audio, then install the sound card, then install the driver?
Or, install the sound card, then disable high definition audio, then boot into windows and install the driver?
I would think that I install the sound card, then go into the bios and disable the high definition audio, then boot into windows and install the driver.
GeForce GTX 760
  Quote Cretae Quote  Post ReplyReply bullet Posted: 28 May 2010 at 6:16pm
I would go into your BIOS and disable the onboard audio first. Then power down, unplug your machine, ground yourself (touch your power supply for example) and install the new card. Plug back in, power up to windows. Plug n play will detect a new hardware device. When prompted for a driver, choose the one that says you have it on disk. Pop in your driver disk, install. That should be that.
I recommend the disable first, just in case you don't hit DEL soon enough before windows starts, and it starts detecting new stuff, etc. I'm pretty sure there wouldn't be any conflicts triggered unless you tried to install a sound driver before the on board sound was diabled, but let's be safe.
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
  Quote Alex Quote  Post ReplyReply bullet Posted: 28 May 2010 at 7:32pm
There's a ton of ways to do it. Not any are wrong, as long as you disable onboard audio before you install the sound driver.
The best way is: disable the high definition audio, then install the sound card, then install the driver.
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 28 May 2010 at 8:40pm
Thanks for all the info. I kind of figured as long as both sets of drivers weren't installed at the same time, it would be okay. It must sound like I don't know what I am doing. I actually have swapped hardware before, just never a sound card, and never on a system as nice as this. The fact that this is such a high end system makes me kind of nervous sticking my fat fingers in there.
I have a anti-static wrist band that I have always used in the past. I plan on using that. It's nice to have a source of so many knowledgeable people in these forums. I appreciate it.
By the way, I'm in my second week now with this system, and I couldn't be happier. Every game I play, I just crank up all the settings as high as they go, and it is always without a glitch. I just finished Battlefield 2, and I installed Crysis just to see what it was like to play it at max settings. I cranked everything up as high as it goes, and it plays as smooth as can be. That is a gorgeous game.
I'm trying to get all the games that support Directx 11. I'm getting Dirt 2 next. I also installed the rocket sled demo from the Nvidia site. That is gorgeous too. The 480 graphics card was a really good decision. The overclocked core i7 930 proc. is a beast also. I ran a scan from Spybot Search and Destroy, a scan with Microsoft Security Essentials, and streamed a video from Youtube, all at the same time, and my proc. only hit 5%. I checked it with the performance meter in the task manager.
You people (Digital Storm) built a flawless monster, and I could not possibly be any more satisfied. You have a customer for life.
Edited by Tboy72 - 28 May 2010 at 8:43pm
GeForce GTX 760
  Quote Cretae Quote  Post ReplyReply bullet Posted: 28 May 2010 at 11:00pm
I envy your 'phones, man I hope we got a good enough card.
I've had my system 4 weeks and I know just how you feel. I've never had a better computing experience, and I'm having phun!! Best of luck.  Evil%20Smile
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 28 May 2010 at 11:32pm
Thanks for your help, I'll let you know how much different it sounds than the integrated sound. I'm going to put it in tomorrow morning.  I think I'll be blown away.  I can only imagine what Battlefield 2 Multiplayer is going to sound like.
Thanks for your help.
GeForce GTX 760
  Quote Tboy72 Quote  Post ReplyReply bullet Posted: 29 May 2010 at 10:54pm
I put the sound card in today. No problems at all. I installed the drivers from Creative's site.
The sound is noticeably better with the Creative Xi-Fi Extreem Gamer card. My Tritton Ax PC Pro surround sound headset sounds incredible. It's hard to stop gaming, and my wife is telling me I spend too much time gaming. With a system like this, I'm not stopping.
GeForce GTX 760
  Quote Cretae Quote  Post ReplyReply bullet Posted: 29 May 2010 at 11:32pm
Thumbs%20DownThumbs%20DownThumbs%20DownThumbs%20Down We done got 'er done! Congrats!  Thumbs%20DownThumbs%20DownThumbs%20DownThumbs%20Down
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
This page was generated in 6.738281E-02 seconds.
