usb port cannot supply enough power
Post Date: 2019-03-28
afontz View Drop Down
  Quote afontz Quote  Post ReplyReply bullet Topic: usb port cannot supply enough power
    Posted: 28 Mar 2019 at 5:09am
Hi,
I keep getting the error message that usb port cannot supply enough power. I have tried multiple suggestion but I still receive the message.
I even purchase a USB 3.0 Hub to see what would help but same issues.
Can anyone assist with this?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 28 Mar 2019 at 7:34am
What device are you connecting ?   Some devices do need more power than a USB port can supply.  Adding a hub doesn't help, unless its a powered hub, with its own transformer,  that plugs into the wall to furnish its own power.
5V at 500 mA is about average for motherboard USB ports, but its hardware dependent.  A USB 3.0 does delivery more juice than a 2.0, but again, if the device is calling for more then get a powered hub.
Big%20Smile
Edited by bprat22 - 28 Mar 2019 at 7:38am
  Quote afontz Quote  Post ReplyReply bullet Posted: 28 Mar 2019 at 8:43am
Here are the device I have:
Cosair K95 keyboard
Cosair Scimitar mouse
Elgato HD60S capture card
Elgato Stream deck
Yeti mic
web cam
Astros A40
Using an Anker 3.0 power hub which is plugged into wall.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 28 Mar 2019 at 10:18am
You're not giving much info.  Which device is giving you the message, or all of them ?
How are they plugged in ?  Are some plugged into the mobo, like the mouse and keyboard and others plugged into the hub ?
Basically, if its just one device I would try different usb ports on the mobo, like 2.0 and 3.0 and try the hub.  The hub will have a power capacity, although it should be more than enough for all the devices, but you still need to add up the device requirements vs the hub output.
It's possible a particular device is the issue, but can't tell by the info given.
Big%20Smile
