Using different fans on lynx rgb controller.
Post Date: 2020-02-10
M6101 View Drop Down
  Quote M6101 Quote  Post ReplyReply bullet Topic: Using different fans on lynx rgb controller.
    Posted: 10 Feb 2020 at 9:44am
I was wondering if I can swap out the stock digital storm fans for some Corsair fans but I don’t know if I can use the same rgb controller that already came with the lynx or do I have to buy a whole new kit and set it up. Unless digital storm has some kind of software like Corsairs ICUE.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 10 Feb 2020 at 11:47am
If you pick up a Corsair 3-pack of the LL or ML 120 mm fans, it will come with one Corsair Lighting Node Pro module included that links the Corsair fans and allows you to use iCUE software to control the RGB colors. You can buy those Corsair 3-packs on the Corsair site, amazon, NewEgg and lots of other places.
  Quote M6101 Quote  Post ReplyReply bullet Posted: 10 Feb 2020 at 3:21pm
Thanks but what I meant was if I already have one of those rgb controllers installed by digital storm, can I just buy new fans and plug it in there or do I have to swap that out. The pc came with 4 rgb fans and I wanna add 2 more rgb fans.
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 10 Feb 2020 at 7:19pm
Well then you need to know if there are 2 available fan ports left on whatever RGB controller they used.    Might need another DS controller if all fan ports are in use, and you would want the exact same DS RGB fans to match what you have..
Don’t think you will use that controller if you were to add Corsair fans...
You would need Corsairs controller unit.
  Quote M6101 Quote  Post ReplyReply bullet Posted: 10 Feb 2020 at 7:30pm
I just checked and I have 2 slots open for fans. I guess I’ll just plug the Corsair fans here.
MadaFaqa View Drop Down
  Quote MadaFaqa Quote  Post ReplyReply bullet Posted: 09 Jul 2020 at 8:04pm
Did you manage to get the Cosair fans and did the RGBs work? I bought some generic cheap argb 120mm fans which worked but the argb 4 pin(3 pins with one hole missing) doesn't fit in the small 3 pin connectors on the controllers DS uses so the fan spins but theres no RGB :(. Just wondering if you managed to find out the brand or what types of individual fans DS uses for the Lynx. I also got a lynx and want to add some additional ones.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Jul 2020 at 3:37am
For those looking, MadaFaqa was answered elsewhere by Stellar with DS. The Lynx fans are custom DS designs, and they will happily sell additional ones.
