Vanq II Light Switch?Post Date: 2014-05-30 |
Author | ||
Tiwaz
Newbie Joined: 30 May 2014 Online Status: Offline Posts: 9 |
Topic: Vanq II Light Switch? Posted: 30 May 2014 at 9:01pm |
I'm interested in purchasing the Vanquish 2 and I'm curious if there's a way to turn off the bright blue light while the computer is running. Maybe I'm just getting old but the light doesn't do anything for me aesthetically. It's not a deal breaker for me, but it is one of the only reservations I have about ordering the machine. If there's a way to make it not look like a UFO is landing in my office, that would be sweet! Thanks in advance.
Nav
Quote Reply Posted: 30 May 2014 at 10:00pm | |
There is no internal lightning except the two front LED fans. Unfortunately, there is no LED switch on them so you can't really turn them off unless you swap out the fans.
Tiwaz
Quote Reply Posted: 30 May 2014 at 10:14pm | |
Ah, bummer. It was the two front LED fans that bothered me the most. Maybe I can get used to it though. The rig is too good of a deal to pass up. Thanks for the timely response. :)
Nav
Quote Reply Posted: 30 May 2014 at 10:37pm | |
No worries! The lighting is more pronounced in the pictures than in person.
Snaike
Quote Reply Posted: 31 May 2014 at 3:16am | |
When did this change? I have a bright blue LED strip on the bottom of the Corsair 230T case that lights up all of my Vanquish II Ultimate's innards.
And no, the front two fans do not have a shut off switch. You'll have to replace them with non-lit fans. Seems fairly simple to do.
Quote Reply Posted: 31 May 2014 at 7:24am | |
Yeah, that changed a month or so ago when they ran out of one model, Grey I believe, and went with the Black case for awhile. Then stayed like that. |
Tiwaz
Quote Reply Posted: 31 May 2014 at 7:49am | |
Unfortunately, it won't let me customize the rig before ordering and I'm not savvy with hardware enough to go replacing fans. It's sort of why I'm not building my own rig in the first place. I don't trust myself enough to not somehow manage to screw up even the simplest of tasks lol |
Quote Reply Posted: 31 May 2014 at 7:55am | |
Hi Tiwaz.... The Vanquish are pre-built and ready to ship , meaning there is no option to customize the builds like their other systems.. That's why they're so good a deal.
LED fans I've seen aren't very bright or annoying at all, just a soft glow, but everyone has their own definition of bright. |
Tiwaz
Quote Reply Posted: 31 May 2014 at 8:06am | |
Yea its a really good deal. I'm looking at getting the level 4. My main issue with the light is that my computer is in the same room where I sleep so I wouldnt be able to leave the computer running at night because the light would keep me awake (I need a pitch dark room). But I guess it's probably better to shut this kind of computer down just so it can cool down instead of leaving it running all the time. |
Quote Reply Posted: 31 May 2014 at 8:15am | |
I shut my rig down every day when I'm done. Leaving it on doesn't hurt but neither does shutting it off.
If the lights really do start to bother you, and if this case is like Corsair's others, then three clips on either side of the front panel releases the panel for easy access to the fans. Four screws in each fan and a cable that plugs in. Vanquish level 4 is a real nice setup. Can't beat the price for the gtx 770, four core processor, etc. If your monitor is a 1920x1080 or less then gaming is nice. Good Luck and stay in touch. |
Snaike
Quote Reply Posted: 31 May 2014 at 9:54am | |
Oh, lights and sleep are no worries... I let my Vanq sleep overnight so the only light I get off of it is the soft blue power button... the fans/lights don't stay on all the time.
Unless you're dl'ing massive amounts of data while you sleep, there's no reason to keep the machine powered up and lit. (Thanks bprat, I wasn't aware that I got one of the last LED bar machines, and that they quit installing them... I still love the way it looks.) |
Quote Reply Posted: 31 May 2014 at 10:07am | |
Hang on to it. Might be a collectible worth big bucks. |
Tiwaz
Quote Reply Posted: 31 May 2014 at 11:21am | |
Yea when I'm doing video editing work, it takes forever and a day for a video to render and export, so I'll let it do its thing overnight while I sleep which means leaving the computer running. But it's good to know that the fan lights don't stay on while the computer is in sleep mode. That's good enough for me. |
blujadajhdja
Newbie Joined: 21 Apr 2014 Online Status: Offline Posts: 3 |
Quote Reply Posted: 02 Jun 2014 at 3:46pm | |
Wait, really? For some reason, losing the LED strips turns me off. There's no way to have the LED strip installed specifically for yourself, right? Being premade and all. |
Quote Reply Posted: 02 Jun 2014 at 3:57pm | |
Nope. No changes to the Vanquish pre built systems. You can do it yourself. It mounts easily and hooks to a peripheral power plug in the harness. Here's an example...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811994001 Hope this helps. |
Snaike
Quote Reply Posted: 02 Jun 2014 at 4:11pm | |
I had to check and bprat is right (again!). It's a very simple procedure to lay the blue LED strip just under the case window and plug it in to the harness.
(I think I'm going to get a petition to get bprat hired as the East Coast representative of DS!) |
blujadajhdja
Quote Reply Posted: 02 Jun 2014 at 4:26pm | |
Well then, that was actually very helpful and I have to say, bprat, you're probably the most helpful person I've ever seen in any forums. |
Quote Reply Posted: 03 Jun 2014 at 2:56am | |
Thanks. Always a pleasure.
Good one, Snaike. |
