Vanquish 3 FanPost Date: 2015-11-10 |
Hordo7
Newbie Joined: 07 Oct 2015 Online Status: Offline Posts: 7 |
Topic: Vanquish 3 Fan Posted: 10 Nov 2015 at 10:28pm |
Hey guys,
I have had a Vanquish 3 level 2 for a few weeks now. I absolutely love it but noticed the top fan in the front isn't spinning. I wanted to see if this is normal or if it is something I need to fix. i don't know much about computers so I wanted to check with you guys. Any help would be greatly appreciated. Thanks! Drew |
Snaike
Quote Reply Posted: 11 Nov 2015 at 1:40am |
Not normal. Vanquish front fans spin 100% of the time. The experts will be along shortly to help you track down the issue.
In the meantime, keep a weather eye out for your temps (HWMonitor, Speccy, etc) One fan shouldn't cause immediate problems, but it's something that needs to be working. Good luck! |
Quote Reply Posted: 11 Nov 2015 at 2:35am |
Sounds like the fan is unplugged. Pull off the side covers and trace the wire from the fan to probably the motherboard. If it is plugged in then the fan might be defective. You could swap where it's plugged in to where the other fan is plugged in to make sure it's the fan and not the header it's plugged into.
Hordo7
Quote Reply Posted: 11 Nov 2015 at 10:17am |
I figured it out. One of the connectors had come unplugged. Thank you for all the help guys!
Quote Reply Posted: 11 Nov 2015 at 10:36am |
