VANQUISH 3 Level 3/4 Question(s)Post Date: 2015-06-03 |
jshaw221b
Newbie Joined: 03 Jun 2015 Online Status: Offline Posts: 3 |
Topic: VANQUISH 3 Level 3/4 Question(s) Posted: 03 Jun 2015 at 10:09pm |
Hi,
I am probably going to purchase a VANQUISH 3 Level 3/4 in a few days, but I have some questions. I am sort of a PC gaming newbie! 1) Will this run games on high/ultra for the next few years? 2) Can I connect to the internet over wifi, or do I need to connect it to a dsl line? I can only get wifi in my room. 3) Is the 1tb enough storage? 4) Do I need more than 8gb of RAM? 5) Is the GTX 970 powerful enough to last 4-5 years? Thank you in advance! Jack |
Quote Reply Posted: 04 Jun 2015 at 2:41am |
Hi jshaw221b......
1...Depends on your monitor/s, but if its a single 1080p then high/ultra settings should be no problem. Can't predict what gaming will look like in 3-5 years, but a graphics card is usually good for 3 years or so with similar settings. 2...doesn't come with WiFi. A usb Wi-Fi adapter is easy to add and relatively inexpensive. Amazon has lots to pick from. 3...Depends on your needs, but 1Tb will hold a ton of games. Plenty for most. 4...8Gb is all you need for gaming. 5...answered this in first question. The Vanquish lvl 3&4 are excellent rigs at a great price. Tough to beat. Hope this helps and good luck. |
