Vanquish 7 Level 2 Question
Post Date: 2018-10-26
RG2 View Drop Down
  Quote RG2 Quote  Post ReplyReply bullet Topic: Vanquish 7 Level 2 Question
    Posted: 26 Oct 2018 at 5:53pm
Hello,
I plan on buying the Vanquish 7 Level 2 but have a question. Will it be able to run Call of Duty Black Ops 4 with high settings? This is the only game I plan on running on the PC.
Thank you for your time!
RG2
  Quote Cretae Quote  Post ReplyReply bullet Posted: 27 Oct 2018 at 11:21am
Unfortunately, no. The Vanquish Level 3 is the perfect fit. The GTX 1060 6GB will deliver consistent 60+ frame per second at 1080p and max settings in lots of games including COD BO4.
With the Level 3 you get a blazing fast i7 8700 CPU, a 240GB SSD, and the 1060. Well worth the extra $400 for the step up across the board in performance.
The alternative for you could be to order the Level 2, sell the 1050 Ti it comes with and replace it with a 1060 6GB. If you can get $100 for the 1050, you could get a 1060 6GB for around $275, net $175. If you could handle that, you'd get a capable rig for around $1174 plus shipping.
Hope it helps you.
RG2 View Drop Down
  Quote RG2 Quote  Post ReplyReply bullet Posted: 28 Oct 2018 at 3:05pm
Thank you very much for the response.
The Level 3 seems like the perfect fit after doing some further research. Will discuss further after it is shipped!
Cheers!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 29 Oct 2018 at 5:09am
So happy to help! It's great you could stretch your budget for the right fit. You won't regret it!
This page was generated in 8.496094E-02 seconds.
