Vanquish Tier 3 cooling limits?
Post Date: 2013-11-09
ChrisKirkman View Drop Down
  Quote ChrisKirkman Quote  Post ReplyReply bullet Topic: Vanquish Tier 3 cooling limits?
    Posted: 09 Nov 2013 at 7:12pm
I would just like to know just what is the heat/cooling limit for the Vanquish tier 3, and How long can you play on it without having it over heat and cause damage to any interior components. Thank You!
Nomad1970 View Drop Down
  Quote Nomad1970 Quote  Post ReplyReply bullet Posted: 09 Nov 2013 at 7:28pm
Unless something bad happens, forever.  Everything should either throttle back or shutdown if there is a heat problem.
My Precious 2
I7-9700 oc 4.7GHz
SSD M.2 1TB Samsung 970 EVO
240GB Samsung 860 Pro SSD
1TB W.D. HD
EVGA GTX 1080Ti
