Velox Case Fan Color Control With Corsair RGB Fans
Post Date: 2021-08-12
ShrykeAbysmal View Drop Down
  Quote ShrykeAbysmal Quote  Post ReplyReply bullet Topic: Velox Case Fan Color Control With Corsair RGB Fans
    Posted: 12 Aug 2021 at 10:11am
I was wondering how the colors on the RGB fans in the Velox are controlled. I have a remote that appears to only control the colors on the LED strip on the side of the system. I have Armour Crate which does have configurations with Aura Creator that control what the CPU cooler colors are doing, and I usually have that on the Smart setting and on Temperature so I can tell at a glance how hot the CPU is. But so far I see nothing in Aura Creator that seems to control the case fan colors either.
I must have done it at one point because they are currently cycling rainbow colors just like the strip but I don't remember where it's done. Anyone have any ideas? My config is below, and lists the Corsair RGB fans as being "software controlled". Is that software that came with the machine or do I need to download something like iCue to control them?
Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish
Processor: AMD Ryzen 9 3900X (12-Core) 4.6 GHz Turbo
Motherboard: ASUS PRIME X570-P / MSI X570-A Pro (Up to 2x PCI-E Devices) (No SLI Support) System Memory: 32GB DDR4 3200MHz Digital Storm Performance Series Power Supply: 1200W Silverstone / EVGA / Thermaltake (Modular) (80 Plus
Gold)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (500GB Seagate FireCuda 520) (NVM Express) (Gen4
PCIe)
Storage Set 2: - No Thanks
Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce RTX 3070 8GB (Performance Edition) (VR Ready) Sound Card: Integrated Motherboard Audio Add On Card: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex Liquid CPU Cooler (Dual Fan) (Fully Sealed + No Maintenance) HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Exotic Cable Management - Green - (Cable Combs with Custom Color Sleeved Extension Cables) Chassis Fans: Corsair LL Series (RGB Fans) (Software Controlled Effects) Internal Lighting: Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks
Graphics: - No Thanks, Please do not overclock my video card(s) OS Boost: - No Thanks, Please do not tweak the services on the operating system Operating System: Microsoft Windows 10 Professional (64-Bit Edition) Recovery Tools: USB Drive - Windows 10 Installation (Format and Clean
Install)
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
DigitalStorm Velox
Ryzen 3900X 32GB PC3200 Digital Storm Certified RAM
NVidia RTX3070 8GB
Segate FireCuda PCIe4 500GB, 2x WD Caviar Black 1TB
Silverstone 1200W modular PSU
  Quote ShrykeAbysmal Quote  Post ReplyReply bullet Posted: 12 Aug 2021 at 10:39am
Nevermind! Just installed iCue and OH WOW!!!!
DigitalStorm Velox
NVidia RTX3070 8GB
  Quote Snaike Quote  Post ReplyReply bullet Posted: 12 Aug 2021 at 10:46am
Another satisfied customer!
fwfdfireman View Drop Down
  Quote fwfdfireman Quote  Post ReplyReply bullet Posted: 12 Aug 2021 at 1:37pm
It takes a bit of time to get the hang of iCue, at least it did for me. If you search the web you can find some great iCue profiles for your Velox. When I found them, I just selected the "Lighting" portion of the profile and not the whole file. Selecting the whole profile will change fan curves and other things.
Good luck and have fun.
Old Gamers Never Die!
