Velox Liquid versus Apollo Air
Post Date: 2014-10-24
smit9448 View Drop Down
  Quote smit9448 Quote  Post ReplyReply bullet Topic: Velox Liquid versus Apollo Air
    Posted: 24 Oct 2014 at 1:04pm
Between the following two builds which one would you recommend for gaming at up to 4k resolution? Both are almost the same price and I know that with the Apollo build I could change it to the Intel Core i7 5930K 3.5GHz to save some money as games are not going to take advantage of 8 cores for awhile.
Configuration Code: 1070303
Chassis Model: Special Deal Hot Seller - Digital Storm Apollo
Processor: Intel Core i7 Extreme Edition 5960X 3.0GHz (Eight-Core) (Extreme Performance)
Motherboard: ASUS X99 RAMPAGE V (Intel X99 Chipset)
System Memory: 16GB DDR4 2800MHz Corsair Vengeance LPX (High-Performance)
Power Supply: 1050W Corsair HX1050
Optical Drive: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R)
Storage Set 1: 1x SSD (256GB Samsung 850 PRO)
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX)
Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans)
Airflow Control: - No Thanks
Configuration Code: 1070306
Chassis Model: Special Deal Hot Seller - Digital Storm Velox
Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components)
System Memory: 16GB DDR3 1866MHz Corsair Vengeance Pro (High-Performance)
Extreme Cooling: H20: HydroLux Level 3: Digital Storm Exotic Custom Cooling System (2x Video Cards + CPU + Chipset)
Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software)
Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Oct 2014 at 2:18pm
Hi smit9448... If it was me, I'd do a combo of the two. If you don't plan on adding a 3rd video card for tri sli, then the second build with Noctua on stage 1 overclock is best for the money.   If you want water cooling then go for it, but not needed. It is nice but more of a luxury.
If you want the option to tri sli then the first build with the 5820k cpu works great.   Like you said, 8 core isn't needed and the only realistic difference between 5820k and 5930k is the number of Pciex lanes from the cpu. 5820k has 28 lanes for x8x8x8 and 5930k has 40 lanes for x16x16x8.   No real difference between x8 and x16 with gen 3.0.
Hope this helps.
  Quote smit9448 Quote  Post ReplyReply bullet Posted: 24 Oct 2014 at 10:23pm
Thank you for your advice this is the configuration I am thinking about going with now.
Configuration Code: 1070600
Processor: Intel Core i7 5820K 3.3GHz (Six-Core) (Unlocked CPU)
Graphics Card(s): 3x SLI Triple (NVIDIA GeForce GTX 980 4GB (Includes PhysX)
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Oct 2014 at 3:19am
Looks great.
Putting the money saved with the changes into a 3rd gtx 980 will be real nice for 4k gaming.
Good luck and stay in touch.
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 01 Nov 2014 at 4:30pm
Looks great.
Which, ironically enough, will really want liquid cooling. As we were discussing in another thread. Three cards that close to each other, heating each other up, and blowing all that hair back into the case.
Better get some high grade static pressure fans to keep them cool. Haha, it's always a balancing game here.
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 02 Nov 2014 at 6:41am
This assumes that the graphics cards have custom coolers. With the stock coolers they blow air out of the case. Also, with the Apollo, you have 2x 140mm and a 120mm (bottom intake) blowing air into the case and 3x 140mm fans blowing out of the case. With the upper front intake fan not having anything blocking it. I just don't see air cooling a problem with this case. I am sure if the 3rd graphics card gets too hot during load testing, DS will inform him and suggest a fix.
If anyone would like to see through review of this case, here is one: http://www.anandtech.com/show/7904/corsair-graphite-760t-case-review
smit9448, looks like a very solid build.
Edited by danjw1 - 02 Nov 2014 at 6:51am
