Venom's input on Power Supplies
Post Date: 2010-12-18
  Quote !ender_ Quote  Post ReplyReply bullet Topic: Venom's input on Power Supplies
    Posted: 18 Dec 2010 at 11:14pm
Originally posted by venom
And you just said it yourself, I have direct access all the time to these PSUs. I work with them on a daily basis, I have tested 1000s of them and guess which one I continually recommend? That in itself should be more than enough reason, though I know you wont agree with that, so how about if you want me to get into a more detailed explanation of why I recommend them, what the differences are, and anything else, I will.
Alright, lets do it. Power supply reccomendations are rarely backed up with proof by anyone here, so lets take the chance to all learn from eachother and put the numbers where our mouth is.
As some important points to hit:
more of the long-term reliability + stability, ripple + noise suppression, and voltage regulation.  I mean if the 750w is only +$30, and the 1000w is only +$44, I would say why not get a Corsair for that little of a difference in price.
Numbers and instrument readings please. I understand you find the Corsair better in every way, I'd just like to see the proof. Since you can list all of these as a reason to spend money, I assume you have numbers to back it up, so maybe a lineup and comparison of:
750w Certified
750w Corsair
1000w Certified
1000w Corsair
1200w Certified
1200w Corsair
Addressing:
Stability
Ripple
Noise suppression
Voltage regulation
I'm especially interested in this difference since here you said jumping from 2 physical cores to 4 physical cores was a good idea for saving $26, which is notably less than the jump to "Corsair Brand" for any of these power solutions.
Edited by !ender_ - 18 Dec 2010 at 11:15pm
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 1:16am
It may take some time.
I will unfortunately be unable to test the oscilloscope on the TechNPS power supplies as the load tester is not complete.  In the mean time, I will post some similar power supplies until the load tester is complete, which will then replace those.
Regarding the CPU, all I was stating was that for gaming, the dual vs the quad didn't make a huge difference in gaming performance.
Edited by venom - 19 Dec 2010 at 1:17am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 1:37am
ender when you ordered your pc did you order DS certified or brand name?
rholyrag View Drop Down
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 8:23am
venom, looking forward to your test results.  Thank you in advance for compiling the data, we appreciate your time and effort.
  Quote venom Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 5:33pm
No problem.
I may ask management if we could send 3 units of TechNPS PSUs to the same review site I will be getting the Corsair data from, as the load tester does not have an ETA for completion.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 19 Dec 2010 at 9:47pm
i built mine, so i chose corsair for its vastly better warranty.
surf71zx View Drop Down
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 10 Jan 2011 at 10:27am
Can you tell me who does the best reviews on power supply testing? Web site address if you have it.Over a dozen power supply vendors out there,whos the best?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Jan 2011 at 10:31am
There are not very many that are good review site for power supplies, here is one that is pretty good.
Just because there are many vendors, does not mean much, when there is only a few compainies that make power supplies.. most just slap there name on it and call it good.
Edited by justin.kerr - 10 Jan 2011 at 10:33am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Jan 2011 at 2:26pm
Ya lot of psus, are a rebrand, or a clone, and keep in mind clones don't even get tested, yet certified. Brand names like corsair pus-s are not a a clone, they actually get tested before they get any certification.
Edited by DST4ME - 10 Jan 2011 at 2:28pm
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 11 Jan 2011 at 9:16am
I bought an ULTRA 1200 psu to put in my Digital Storm there building right now.Thinking having a life time warranty it  must be good.Wrong!!!! It failed miserably all tests.Digital Storm is pulling that out and replacing with Corsair AX 1200 with 7yr. warranty.It received one of the highest ratings and reviews you can give a psu!!!!!  THANK YOU for the web sites to look at!!!!!!!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Jan 2011 at 12:12pm
Corsair AX 1200 is a very good psu with a 7 year warranty, when it comes to psu, you can't go wrong with hx and ax in the corsair, and the tx is better then the generic psu here.
You have to look at the maker of the psu, its/their track record and the warranty, sometimes the warranty itself is not enough.
Edited by DST4ME - 11 Jan 2011 at 12:13pm
