Vertical GPU mount for VOLEX case?
Post Date: 2022-11-29
velox_xxx View Drop Down
  Quote velox_xxx Quote  Post ReplyReply bullet Topic: Vertical GPU mount for VOLEX case?
    Posted: 29 Nov 2022 at 10:00am
Has anyone tried an universal gpu vertical mount on the volex case? i haven't seen any pictures in the galleries that has one. Being rotated, I was wondering if there is a mount capable holding a gpu upside-down.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 30 Nov 2022 at 1:11am
The Velox has a lot of space inside the case for any gpu and since the mobo is upside down you get to see the best part of the gpu!
 Also, you would have to fabricate the vertical slot in the back of the case for the gpu to bolt on and have its ports available. But that would be an interesting mod.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 30 Nov 2022 at 12:58pm
Go to Amazon and search “GPU vertical mount” and all kinds of options pop up.    They use the same type riser ribbon cable option the DS Bolt uses for their vertical mount setup . The riser cable is a flex cable attachment for the Graphics card PCI interface to the motherboard pci slot.   Not sure if the back plate on the Velox can be removed or cutting is needed.
Hope this helps.
