Vertical Mount for Lynx ?
Post Date: 2020-11-30
Ras View Drop Down
  Quote Ras Quote  Post ReplyReply bullet Topic: Vertical Mount for Lynx ?
    Posted: 30 Nov 2020 at 1:02pm
Anyone in here have a lynx case with vertical mount ? any recommendations on a vertical mount that is compatible ? Phantek seems like they make a nice one ?
Thanks
  Quote Snaike Quote  Post ReplyReply bullet Posted: 30 Nov 2020 at 4:51pm
Vertical mount for a computer? I'm confused. PCs are already vertical by default, no? I've not seen any lying prone.. but my experiences aren't universal either.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 01 Dec 2020 at 4:00am
If you are talking about for the whole case, I have heard that they can restrict airflow because of the surface they are affixed to. best to have a PC open to the air on ALL sides, including top and bottom. Why they come on "feet".
Is that what you mean?
Ras View Drop Down
  Quote Ras Quote  Post ReplyReply bullet Posted: 01 Dec 2020 at 8:45am
I’m trying to say instead of the GPU fans facing down. The vertical mount would just have the fans facing out towards the glass panel displaying the GPU. Just google vertical GPU mount and you will see what I’m talking about. Phantek looks like they make a good one.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 01 Dec 2020 at 9:25am
That is a gpu vertical mount. They are installed in the Bolt because of tight space. No need otherwise unless it is for looks.
Ras View Drop Down
  Quote Ras Quote  Post ReplyReply bullet Posted: 01 Dec 2020 at 1:22pm
100% for looks just trying to see if anyone in here has done it and if the phantek will work with it.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 01 Dec 2020 at 1:34pm
Got it.
Those seem to use 5 slots so if you have them... It would appear that it would not be so straightforward if it was a Velox or Aventum where the gpu(s) are on top of the mobo but I really do not know about that.
All I see is two more connections between my gpu and the mobo. More sometimes is not better. But I don't have lights either. Smile I favor just white or green light.
tfg1955 View Drop Down
  Quote tfg1955 Quote  Post ReplyReply bullet Posted: 01 Dec 2020 at 7:16pm
Li Lian makes a kit. I put one in my Vanquish. They are just to show off your GPU.
This page was generated in 7.104492E-02 seconds.
