Video Card help
Post Date: 2010-07-27
Harry View Drop Down
  Quote Harry Quote  Post ReplyReply bullet Topic: Video Card help
    Posted: 27 Jul 2010 at 6:00pm
First of all I love my DS. It is a great unit and know I made the right decision buying from this company.
But I need some help. My unit in back at DS for a minor tune up and they found one of my GTX 260 is on its last.
It will be forever to get another 260 so here are options and I need help since I have not been following cards for some time.
Option
2-- 280s
one 470
one 460
Gaming and photoshop rig.
Any quick simple advice would be REALLY appreciated.
Harry
Cool Master HAF 932
Core i7 965 DSO OC
Water cooled CPU
ASUS Rampage II Extreme
6 GB DDR3 1600 OCZ
1000 W Corsair HX
GTX 470
300 GB Raptor
tera 7200rpm
Windows 7
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 27 Jul 2010 at 6:03pm
470 no question  unless you are running 30" monitor.
  Quote Harry Quote  Post ReplyReply bullet Posted: 27 Jul 2010 at 6:37pm
Thanks for the quick response. Been doing a little "panic" reviews and the 470 looks like a good card.
Not sure about heat issues, looks like it can get a little hot.
Also trying to find a performance comparison chart for my sli 260s and the 470 without much luck.
Would it be the same or better than my 260s?
I guess one 470 with heat the room less than sli 260s
Harry
Cool Master HAF 932
Core i7 965 DSO OC
Water cooled CPU
6 GB DDR3 1600 OCZ
1000 W Corsair HX
GTX 470
300 GB Raptor
tera 7200rpm
Windows 7
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 27 Jul 2010 at 6:49pm
I have had 2 GTX 260's.. and a GTX 470, the GTX 470 will be very close to the same power. with no AA the GTX 260's will be a touch faster, with eye candy maxed, the GTX 470 will be a tad faster.
The GTX 470 is not that hot, nor that loud, and overclocks like mad. When overclocked a lot it will get hot and loud lol
  Quote Harry Quote  Post ReplyReply bullet Posted: 27 Jul 2010 at 7:21pm
Thank you for your help. Going with the 470.
Thanks again
Harry
Cool Master HAF 932
Core i7 965 DSO OC
Water cooled CPU
6 GB DDR3 1600 OCZ
1000 W Corsair HX
GTX 470
300 GB Raptor
tera 7200rpm
Windows 7
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 27 Jul 2010 at 7:22pm
wait till you see Dx11... lol you will never want to play on flat worlds again!!
This page was generated in 0.1035156 seconds.
