Vista SLI problem
Post Date: 2008-01-23
Lunchbox View Drop Down
  Quote Lunchbox Quote  Post ReplyReply bullet Topic: Vista SLI problem
    Posted: 23 Jan 2008 at 10:27am
Hey everyone, its been quite awhile =O. I isntalled Vista Ultimate 32 bit last night on my second hard drive (150GB Raptor) and today installed everything and i went to my nVidia Control Panel today and went to check SLI and all the settings, and the SLI isnt in the 3D Settings.can anyone explain whats going on? and if SLI is even enabled?
nomec View Drop Down
  Quote nomec Quote  Post ReplyReply bullet Posted: 23 Jan 2008 at 11:40am
First, check in the SLI area in your nvidia control and make sure it's even enabled.  Once that is enabled then your 3d settings will show SLI options.
If it's on and you still arent seeing it in 3d settings (which would be weird) then just uninstall and reinstall your drivers.  Should be a pretty simple fix.
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
Vista Home Premium 64-bit
  Quote Lunchbox Quote  Post ReplyReply bullet Posted: 23 Jan 2008 at 2:23pm
I installed the 169 drivers for 32 bit and i dont have an nVidia control panel, im intensely confused
  Quote Lunchbox Quote  Post ReplyReply bullet Posted: 23 Jan 2008 at 2:38pm
Okay well i went to adjust GPU settings, and Vista isnt registering both my 8800GTXs, only 1.....
Digitalkryme View Drop Down
  Quote Digitalkryme Quote  Post ReplyReply bullet Posted: 23 Jan 2008 at 3:17pm
is it recognising one as unknown hardware or just not seeing it at all?
i would uninstall from the device manager the one that is being recognised along with your display driver then reboot.
Hopefully vista will wake up and detect them, otherwise if you cant get the problem fixed feel free to send me the one its not recognising Tongue
have you done all the updates for vista btw?
Before you mock someone, walk a mile in their shoes, then at least your a mile away and have their shoes as well :)
  Quote Lunchbox Quote  Post ReplyReply bullet Posted: 23 Jan 2008 at 3:21pm
i didnt install the Asus Drivers yet, im dual booting vista on another HD.....i cant find the right drivers, i have the M2N4-SLI mobo, could anyone tell me the right drivers, and whatever else i might need?
  Quote nomec Quote  Post ReplyReply bullet Posted: 23 Jan 2008 at 4:08pm
You could also re-seat both cards and that might do something.
Also, sometimes your system wont fully get rid of the nvidia drivers if you just uninstall it from control panel and then reboot, and reinstall the drivers.  I have been having that problem a lot in vista lately.  uninstall them, reboot, run driver sweeper on just the nvidia display drivers, then install.
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
Dashuu View Drop Down
Guest
Guest
  Quote Dashuu Quote  Post ReplyReply bullet Posted: 23 Jan 2008 at 5:31pm
Here, http://support.asus.com/download/download.aspx?SLanguage=en-us
You can get some of your drivers for a 64bit OS. No chipset drivers oddly enough. Maybe windows has them pre-loaded.
1
This page was generated in 3.613281E-02 seconds.
