Waited for SB, Now Need Help with Gaming Build
Post Date: 2011-01-11
Myrkul23 View Drop Down
  Quote Myrkul23 Quote  Post ReplyReply bullet Topic: Waited for SB, Now Need Help with Gaming Build
    Posted: 11 Jan 2011 at 6:11pm
Hey everyone, so I was waiting for sandy bridge to come out before taking the plunge and buying a new system.  I am looking to spend around $1500.  The computer would be mainly used for gaming on a 1920x1200 monitor.  The only thing I don't need is a fast hard drive since I'll be using my Western Digital velociraptor (600 Gb) from my existing computer.  The plan is to wait for Corsair's new SSD controller and then buy an SSD at that time.  Thanks in advance for any advice you can give!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Jan 2011 at 6:32pm
Intel is the ssd you want, your raptor is nothing close to a ssd, but if your plan is to upgrade then the intel gen 3 ssds should be coming out soon, upgrade to one of those.
at your price range I'm not sure what you want to do, I can't give you a build that is fully expandable, (you can't add another gpu down the road), and at your res you may find that you want to go sli in the future, so the build I'm giving you is not able to go sli in the future do to budget:
Here you go Ticket# 477535 --- $1628 (To see this build click here)
Motherboard: ASUS P8P67 (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s)
Hard Drive Set 1: Operating System: 1x (80GB Western Digital (8MB Cache) (5400 RPM)
now the 2600k has 4 cores 8 threads while the 2500 has 4 cores and 4 threads, this makes little difference in games but in other things it makes a bigger difference, if you only want to game then go ahead and drop the cpu to the 2500 and save $100.
clone the 80GB to your raptor, I figured you got a HDD you want to spend least on it here.
  Quote Myrkul23 Quote  Post ReplyReply bullet Posted: 11 Jan 2011 at 6:47pm
Thanks for the advice!  Is the reason why this build can't go SLI due to the motherboard or power supply (or both)?  Also, do you think instead of a 570 I should go SLI straight up?
Final question is if you think bumping up my budget to $2000 would make a significant difference.  Thanks again!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Jan 2011 at 7:31pm
mobo and psu, you can go with the delux that gives you x16/x8 with 2 cards, this board will give you x4/x4, and the psu you gonna want a 1000w corsair.
there is no reason to go sli if you are not sure you need it, its better to just get single and add the second if you need it, it takes 2 minutes for somebody who has never done it.
for sli setup in SB this would do I guess:
Here you go Ticket# 477557 --- $1881 (To see this build click here)
Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s)
here is a nehalem i7
Here you go Ticket# 477558 --- $1896 (To see this build click here)
Processor: Intel Core i7 950 3.06GHz (Quad Core)
Motherboard: ASUS Sabertooth X58 (Intel X58 Chipset) (Features USB 3.0 and SATA 6Gb/s)
the SB has better performance in other tasks, sabertooth gives you two x16 lanes, in games performance should be around the same almost.
  Quote Myrkul23 Quote  Post ReplyReply bullet Posted: 11 Jan 2011 at 7:56pm
Is there a big disadvantage to having SLI on an x16/x8 versus an x16/x16 board?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Jan 2011 at 10:04pm
Right now for most games no, perhaps 4 to 6 fps drop, in a couple of games it can be more, as for future gpus, I couldn't tell you, for a dual gpu card it makes a big difference, but we don't recommend those anyways.
  Quote Myrkul23 Quote  Post ReplyReply bullet Posted: 12 Jan 2011 at 4:37am
Ok so I think I'd prefer going with a system that has the option of SLI since I feel like some of the newer games will be tough to play on max settings at 1920x1200.  The build I'm looking at is this...
This is with me swapping in my existing Velociraptor hard drive and upgrading to SSD in the next few months.
Before I take the plunge and order just a couple of quick questions...
1. Is there any benefit in going with the CPU overclock or is it easy enough to overclock on my own?
2. Would it be a major downgrade to go from the 932 to 922 case?
3. Any other suggestions?
Thanks again for all the help!   It's much appreciated.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Jan 2011 at 5:56am
1. these cpus are suppose to be easy to oc, tho they take it upto 3.8GHz for you with the turbo, if I'm not mistaken, in games the higher oc won't matter much, however in everything else it will matter very much, tho a 3.8GHz oc is a great spot, and you can always see what you can push it to yourself if you like, the cpu cooler is a great one and ready to help achieve a higher oc, from what I understand SB runs faster and cooler.
2. 932 is better for expansion if you looking to go sli in the future, it also has a bit better air flow.
3. assuming this pc is meant to add another gpu down the line, then no, no other suggestions.
My pleasure
Edited by DST4ME - 12 Jan 2011 at 5:56am
  Quote Myrkul23 Quote  Post ReplyReply bullet Posted: 12 Jan 2011 at 2:54pm
Just ordered... now the long wait!!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Jan 2011 at 7:09pm
Congrats
just realized you need to change the oc to
Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz
gametamer View Drop Down
  Quote gametamer Quote  Post ReplyReply bullet Posted: 13 Jan 2011 at 12:52pm
I may be wrong but from what ive seen at newegg and tiger direct the p67 boards in sli all run at x8 x8. Ive been looking at them all morning and havent seen one that runs sli at x16 x8.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Jan 2011 at 1:24pm
no, there are boards that can run 2 @ 16x, but, it is either from using a PLX to rob other lanes, or the NF200 chip, to "add" lanes, or a combination of both.
Asus Maximus IV
Gigabyte UD7
MSI big banger marshal
  Quote gametamer Quote  Post ReplyReply bullet Posted: 13 Jan 2011 at 4:01pm
OK  thanks Justin. Not trying to hijack the op thread but if i get the asus maximus board from DSO it will run 2 x16? Just wondering before I buy my system when i go sli I want the full capabilities from my vid cards.
Metamorphosis View Drop Down
  Quote Metamorphosis Quote  Post ReplyReply bullet Posted: 13 Jan 2011 at 4:21pm
Deluxe is even overkill... Pro is all you need offers nothing more then 16+2 DIGI+ VRM instead of 12+2 which nobody can tell me what exactly having more does. And a box that you can put in a front slot to get a couple extra USB 3.0 ports. And also if you run a card in the 3rd PCI-E slot it robs your USB 3.0 if I understood it correctly.
The PCI-E lanes on the new motherboards have double the bandwidth so x8 slots are the same as x16 slots on the older boards. And as far as the boards all I've seen that have 3 PCI-E x16 slots look to be x8/x8/x4 or x8/x8/x8 depending on if its has the NF200 chip or not which is only going to the third slot so it doesn't give any latency at all to the first 2 slots. I haven't seen any board that runs x16/x8 with 2 cards. And you won't see any performance loss.
Especially considering your low budget I wouldn't worry about it.. the loss in performance is unnoticeable especially compared to other areas where you could spend that money and see some difference like a SSD (I agree with you here though on waiting for the next generation) or better CPU cooler (air cooling is plenty for the current set of Sandy Bridges)or just pocketing the extra money and save for a new monitor or 2nd card (usually the 2 come hand in hand). Also somewhere else you could save money is on the powersupply 850watt is plenty for SLi rigs.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Jan 2011 at 4:32pm
PCIe 2.0 16x speed or 8x speed is the exact same on SB as any other motherboard.. PCIe 2.0 does not change based on platform lol
  Quote Metamorphosis Quote  Post ReplyReply bullet Posted: 13 Jan 2011 at 5:02pm
Sorry I was referring to P55 boards not the X58 boards. P55 never really offered true PCI-E 2.0 bandwidth as far as I understood.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Jan 2011 at 5:31pm
on the p67. the asus Deluxe is for dual sli at x16 x8. the pro gives you x8 x8, but for now as justin said it not a big deal.
  Quote Metamorphosis Quote  Post ReplyReply bullet Posted: 13 Jan 2011 at 5:48pm
Wrong.. deluxe is only x8 with dual cards straight from their site
http://usa.asus.com/product.aspx?P_ID=FpufhQASBFHNvccl&templete=2
But like said.. not an issue for any card out currently. And without a crystal ball there's no saying if that will be an issue down the road or not.. but I'm leaning towards it won't be an issue.
The benefits of Deluxe over Pro are best listed here
http://www.bjorn3d.com/read.php?cID=1973&pageID=9982
Edited by Metamorphosis - 13 Jan 2011 at 5:51pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Jan 2011 at 11:33pm
AFter having a second look you are correct, the pro and deluxe are the same in sli /cf, ya right now.
  Quote Myrkul23 Quote  Post ReplyReply bullet Posted: 21 Jan 2011 at 4:32pm
Been stuck in stage 4 limbo for 3 days.  The anticipation is killing me!  :)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Jan 2011 at 4:39pm
LOL hang in there stage 5 is the long one
This page was generated in 0.140625 seconds.
