Water Box
Post Date: 2009-10-08
Psimon View Drop Down
  Quote Psimon Quote  Post ReplyReply bullet Topic: Water Box
    Posted: 08 Oct 2009 at 8:23am
Pretty cool looking chassis available at Danger Den's.
Looks fantastic, but who knows, probably a real beast to work on as compared to a Coolermaster case.
It's awful purty, tho'    Confused
Edited by Psimon - 08 Oct 2009 at 8:40am
CM HAF 932*EVGA X58 3X SLI* i7920 4.0Ghz OC*6GB Mushkin RAM*EVGA Titan Sprclked*Samsung 850 Pro 1TB*Logitech Z5500*Razer Death Adder*Corsair 1000HX PSU*LG 34UM95 Monitor*Windows7Ult64
workingman View Drop Down
  Quote workingman Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 12:41pm
yes they are cool..but any screws used  on the plastic you would  have to be very careful of...unlike metal..the plastic can crack...if too much force were used on the screws...other than that would be about the same i think
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 3:14pm
MountainMods wanna be Justin's wife is getting a moutainmods, if he is gonna light it and everything you will see the real deal.
in all fairness it does look good tho.
Edited by DST4ME - 08 Oct 2009 at 3:16pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 3:29pm
I have a MM case to.. lol
I have one DD case, a torture Rack, don't have any good pics, because it is always torn apart. Smile But they are durable cases, only problem is that the acrylic scratches easy..
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 10:45pm
Here is my little shop rig now for display.
Is this the famous DST  S & M future chamber?? or the Rooster exercise lot? SmileSmile
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 10:59pm
lol, yeah it is great RAM  suprised nobody said anything about my single pump running a paraleel loop... not too many like that out there.. prolly a reason .lol
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 11:32pm
2 loops 1 pump.... lol
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 4:50am
that is a sweet rig justin, is that a 480 gtx?
dang that is a parallel isn't it, I did even notice that at first.
Edited by DST4ME - 09 Oct 2009 at 4:52am
Roadkill331. View Drop Down
  Quote Roadkill331. Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 5:27am
The guys over at Smoothcreations can turn every case especially DD ones into a work of art.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 9:19am
OK
How and Why ?           Confused
It works very well for testing, makes it easy, no matter if the GPU's are water or air, same with the CPU, MOBO,
The pump has to outs and two ins. it can be a problem if one loop is extremely restrictive and the other is very free flowing, but it has worked on every setup I have put on it so far, and that is a lot of em. lol
DST, yes that is a GTX 480 on that side, and a GTX 240 on the other side, but it did not make the picture. lol
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 1:41pm
so how come you didn't use the feser instead of 480?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 3:54pm
I have a feser 360 in my MM build, and XSPC RX 360 and 2 Swiftech triples..  they are all geared for good cooling with low speed fans... The test bench is a different story, nothing can come close to the GTX  when it has 3000+ RPM fans, loud but will cool very well.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 4:00pm
gotcha
This page was generated in 6.494141E-02 seconds.
