water cooled memory
Post Date: 2009-08-17
Outlawsys View Drop Down
  Quote Outlawsys Quote  Post ReplyReply bullet Topic: water cooled memory
    Posted: 17 Aug 2009 at 11:12pm
I'd like to hear what you guys think about this:
OCZ Flex EX Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kits Desktop Memory Model OCZ3FXE1600C7LV6GK
is it worth water cooling the memory? what kind of fans does DS use on the mushkin memory, i'd like to see a picture of the fan kit, maybe someone has the product part number so i can look it up i have 12 gb of memory on the MB coming soon. oh does it require 2 fan kits for the 6 sticks?
boy i just found these online can i use these with the mushkin : http://www.koolance.com/water-cooling/product_info.php?product_id=860
Edited by Outlawsys - 17 Aug 2009 at 11:24pm
Old Legends Never Die
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 18 Aug 2009 at 12:02am
go with fan
triple channel ddr3 doesnt get very hot
  Quote Outlawsys Quote  Post ReplyReply bullet Posted: 18 Aug 2009 at 12:20am
does anyone know what model number the mushkin 12 GB 1600 DS certifed enhanced memory is so i can look it up also the type of fans used. I looked on mushkins site but they don't show a fan kit for their memory. http://www.mushkin.com/doc/products/performance/
Edited by Outlawsys - 18 Aug 2009 at 12:23am
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 18 Aug 2009 at 1:45am
not sure why your getting 12gbs but go look in the Review section, people have pictures of the inside with the Memory fans
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Aug 2009 at 2:43am
ocz has not been doing great here so they dropped it.
LCing ram is pointelss.
the mushkin ram they are using is 8-8-8-24, it does not have a fan kit, the fan kit you get will either be ocz or corsair.
This page was generated in 0.1260071 seconds.
