Water Cooling maintenance
Post Date: 2008-09-15
Giao View Drop Down
  Quote Giao Quote  Post ReplyReply bullet Topic: Water Cooling maintenance
    Posted: 15 Sep 2008 at 5:49pm
Ok so perhaps a lame question but I couldn't find much on this on these forums:
Do I need to perform regular maintenance on my Frostbite Water cooling system?   IE changing the fluid out or topping off every once in a while?  I was checking out other mod sites and one thread talked about changing it out as frequently as 1-2 times per year?!
if this is the case, is this a daunting task for a noob to the modding process?
Thanks!
P.S: I purchased my system from DS in May of 2008 so its not that old...~ 4 months.
Rolet View Drop Down
  Quote Rolet Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:11pm
I've heard many things. It can last 5 years then you gotta refill it, but the recommendation is every 6 months to keep everything fresh. I haven't actually done any refill since I got my computer in july.
x9700 @ 3.60 Ghz
XFX 790i Ultra
1200W PC Power & Cooling ESA
2 8800 Ultra OC
4GB 1800 OCZ
150g raptor (Raid 0), 1TB
Watercool CPU/Dual GPU
Creative XiFi Fatality
Vista Ultimate 64-bit
Axel Daemon View Drop Down
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:29pm
http://www.xtremesystems.org/Forums/showthread.php?t=119699
posted by MaxxxRacer: "In a properly setup watercooling loop little to no maintenance is required. For example, in my nearly airtight sealed loop I have not touched it for over 6 months, not even to add water. There will always be some water evaporation through the plastics and metals of the system, but this is minimal. On the other hand if you are running an unsealed system, you will have to add water on a regular basis. Some uses have reported having to add water every week to keep the system filled. With regards to cleaning, as long as you clean the system properly the first time it should have little to no particulates in the water other than the common white haze that plagues all watercoolers. This means that you dont really ever need to clean it unless you start to see something unusual happen such as algae growth."
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:34pm
If you go with one of these cases like haf or cosmos s, they have a refill slot on the top and very easy.
you probably will need to check level and add liquid if needed every 6 month. you may want to change the liquid every 5 years.
  Quote Rolet Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:37pm
OMG thats awesome. I wish the 950i case had that.
x9700 @ 3.60 Ghz
XFX 790i Ultra
2 8800 Ultra OC
4GB 1800 OCZ
Kelly View Drop Down
  Quote Kelly Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:47pm
it can. Have Dremel will travel ;)
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:48pm
You keep bringing that up but that kinda forces you to only have a specific type of reservoir right?  Unless all reservoirs have their hole in that exact spot....
@Kelly: This is probably why case modding must be so much fun if you intent to massacre the case when you first have it lol.
In fact what kind of "case modding" do you guys do really?  Was that a joke, or you really do offer that type of custom service?  If so that made even more emphasis on "You dream it we build it" lol.
Edited by Axel Daemon - 15 Sep 2008 at 6:49pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:50pm
You have to ask DS about the reservoirs
  Quote Kelly Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 6:57pm
well let's say if we do, do that... we would get a special "re-tapped" Top Port version of the reservoir we currently used, then get a fill port to run down to the reservoir.
Hell yes, case modding is fun, but we don't offer a lot of services unless you're a magazine or someone we want to show off too :-P
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 7:00pm
In that case perhaps Rolet forgot to mention that he works for ABC News
  Quote Rolet Quote  Post ReplyReply bullet Posted: 15 Sep 2008 at 7:07pm
LOL
x9700 @ 3.60 Ghz
XFX 790i Ultra
2 8800 Ultra OC
4GB 1800 OCZ
This page was generated in 9.179688E-02 seconds.
