Water cooling Ram
Post Date: 2010-01-01
Newbieevgaati View Drop Down
  Quote Newbieevgaati Quote  Post ReplyReply bullet Topic: Water cooling Ram
    Posted: 01 Jan 2010 at 11:10pm
Justin, Kerr
     I wanted to ask if the water block in your first photo was the DS unit.  If so which set-up?  Further do they remove all of the mobo's fins (EVGA). To do liquid coolin?
     Second the first photo of your ram.  Mushkin is that the 6gb sold at DS.  I think they are the ones I ordered, I like the color.
Bill
Nice rig...  This was in your reply to a NKAWT9 I believe
Thanks from your loving
Forum W.....
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Jan 2010 at 11:40pm
his block is not the one from DS, I believe that is his heat killer WB.
the mobo WB takes teh place of what ever that was there before, so if you get the mobo block then yes they are moved.
he is using the redline, the ones here at DS are not red line.
This page was generated in 6.103516E-02 seconds.
