Water cooling - refill and flush help needed
Post Date: 2024-03-08
Grasshopper3438 View Drop Down
  Quote Grasshopper3438 Quote  Post ReplyReply bullet Topic: Water cooling - refill and flush help needed
    Posted: 08 Mar 2024 at 6:33pm
I have am Aventum X, and I need to drain and refill the coolant liquid. Can anyone recommend a kit and fluid for this job?
smfcpa View Drop Down
  Quote smfcpa Quote  Post ReplyReply bullet Posted: 08 Mar 2024 at 9:16pm
You can get it thru DS. I don't think it is just water.
My solution came in a bottle with "Corsair" at the top. It is called "HYDRO SERIES" XL8 Performance Coolant. My solution is "CLEAR" Mine came in a 1000 ml bottle. It took more than one bottle. There is a video showing you how to do a refill. My 4 year old Aventum hardly looks any different than it did the day I got it. Why do you think you need to replace it?
My new Aventum has hard copper piping whereas my old Aventum has plastic tubing.
Steve Foulks
Upper Peninsula of Michigan
  Quote hoserator Quote  Post ReplyReply bullet Posted: 09 Mar 2024 at 11:07am
EK has various products for cleaning and flushing systems with instructions.
I also recommend a 24-pin ATX power on/off switch jumper (Amazon) to cycle the pump on/off without having to start and shut down the system. Much quicker and safer.
Good luck.
kimnancy View Drop Down
  Quote kimnancy Quote  Post ReplyReply bullet Posted: 16 Mar 2024 at 1:17am
Sure! You can try the Corsair Hydro X Series coolant kits. They're reliable and easy to use. As for the fluid, Mayhems X1 coolant is a popular choice among PC enthusiasts. Hope this helps!
GrandesBollas View Drop Down
  Quote GrandesBollas Quote  Post ReplyReply bullet Posted: 17 Mar 2024 at 7:15am
With this tutorial, the Aventum X is really easy to drain and re-fill.
https://www.youtube.com/watch?v=5csB1I-Sn-w&t=481s&pp=ygUWZHJhaW5pbmcgZGlnaXRhbCBzdG9ybQ%3D%3D
  Quote hoserator Quote  Post ReplyReply bullet Posted: 21 Mar 2024 at 2:46pm
I am having issues when I try that link (or any link posted here). I get routed back to the origin. Hmmm!!
fwfdfireman View Drop Down
  Quote fwfdfireman Quote  Post ReplyReply bullet Posted: 21 Mar 2024 at 5:25pm
Why the links don't work properly here is a question to be looked at by the web designer.
However, you can "highlight" the link, then right click on it and scroll down where is says, "Go to...... yada yada yada". This will get you there hoserator. :-)
Old Gamers Never Die!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 22 Mar 2024 at 9:53am
  Quote hoserator Quote  Post ReplyReply bullet Posted: 23 Mar 2024 at 2:16am
Thanks guys.
