Water Cooling
Post Date: 2010-11-16
ags76 View Drop Down
  Quote ags76 Quote  Post ReplyReply bullet Topic: Water Cooling
    Posted: 16 Nov 2010 at 5:50pm
I've had my system for over six months now, and couldn't be happier.  Just a minor question -- is it normal to have the water level go down periodically in this closed-loop system?  Not dropping very fast, but is dropping some.  I've added water once (about six weeks ago) and noticed a small level of drop since then.  Is this normal?
Thanks!
Cooler Master HAF X
Intel i7 930 @ 3.9GHz OC
ASUS P6X58D Premium SLI
6GB DDR3 1600Mhz Ram
1000W Corsair
150GB Velociraptor, 1 TB WD
2x NVIDIA GTX 470 1.2GB
Sub-Zero LCS Dual Loop
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 16 Nov 2010 at 6:02pm
Air trapped inside will work its way into the reservoir, so the water level will drop a little bit at first, then it should drop a tiny bit over time, due to evaporation through the tubes.
what kind of water did you add?
  Quote ags76 Quote  Post ReplyReply bullet Posted: 16 Nov 2010 at 9:12pm
Thank You.  I added Distilled Water
Also, the small light behind my reservoir has started acting up.  Sometimes it works fine.  Sometime it is very dim.  Sometimes it flashes rapidly on and off.  Sometimes it goes out completely.  Any idea what that is all about?
Thanks much again.
Edited by ags76 - 16 Nov 2010 at 9:17pm
Cooler Master HAF X
1000W Corsair
