Water Cooling
Post Date: 2008-09-27
Ace Zoot View Drop Down
  Quote Ace Zoot Quote  Post ReplyReply bullet Topic: Water Cooling
    Posted: 27 Sep 2008 at 4:24pm
I just got my DS computer and it has CPU water cooling.  It gurgles about every 10 seconds.  I looked at the small reservoir in the case and it looks full.  But when it is running it seems to have a lot of air in the fluid.  I went with the water cooling so it would be alittle quieter but it is not.  Any thoughts? Do you check the level when it is off or running?  It does not have any documentation.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 4:50pm
Call DS, it does have a little liquid sound, but it not suppose to be no biggie, they will know if your setup is ok or needs some love.
  Quote Ace Zoot Quote  Post ReplyReply bullet Posted: 27 Sep 2008 at 11:45pm
I emailed them earlier and I was told it was normal to gurgle. but every 10 seconds??
Does anyone know when to check the water level?  ON or OFF?
Thanks!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Sep 2008 at 12:24am
ON should be fine
  Quote Ace Zoot Quote  Post ReplyReply bullet Posted: 28 Sep 2008 at 11:55pm
Thanks for the info.!!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Sep 2008 at 12:59am
Pleasure boss and you are very welcome
