Water Cooling Vs Air Cooling
Post Date: 2008-03-05
Joker3 View Drop Down
  Quote Joker3 Quote  Post ReplyReply bullet Topic: Water Cooling Vs Air Cooling
    Posted: 05 Mar 2008 at 6:10am
I am just wondering since water cooling is so expensive compared to air, is it necessary to use water cooling in a SLi set up or can you get away with air cooling just fine?
MarkNY View Drop Down
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 05 Mar 2008 at 9:22am
With the proper case and fans, I don't think liquid cooling is necessary or really worth it at all for SLI unless you are going to a) go for dual loop or b) just want something exotic in your system.  But i'm no expert...
Dog Lover View Drop Down
  Quote Dog Lover Quote  Post ReplyReply bullet Posted: 05 Mar 2008 at 12:00pm
I have the extream case and the 6850 processor and I had to go with liquid cooling for the processor only as it was just roasting under load.  I think that once you over clock it, and throw in the dual cards, its heat blasting rig.
I would say that if your going high end, such as a system like mine, go with the Thermal Electric (liquid) cooling on the processor just to be safe. Mine rig runs nice and cool and not even a hic-up while playing high end games on the maxed out settings.
But, like MarkNY, I am no expert,  this is just my opinion.
Extreme Case
850 Watt Thermaltake
Qx6850 3.0 Ghz (stock speed)
780i Motherboard
4 G, 1066 RAM
2X SLI GTX 260, 896
Sound Blaster X-Fi XtremeGamer
Thermoelectric Liquid Chilled
Windows 7,64b
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 05 Mar 2008 at 12:32pm
My take:
It's been months since Kelly of DSO responded to a post I made about air cooling and the 850i vs 950i cases, and after much reading, I finally understand what he was getting at.
Air is a terrible conductor of heat. Water is a reasonable conductor of heat. In order to make up for the performance deficit, air cooling requires *volume*. Huge amounts of air need to be pumped through the system in comparison to how much water is needed.
Provided the case is equipped to do just that, air cooling can be extremely efficient. You will *not* be setting any overclock records on air, but at the same time, I run a B3 stepping quad at over 3 GHz and maintain temperatures under 55*C on the cores under load on air. Newer processors can reach even higher speeds with the voltages I use, to the extent that unless you are running triple SLI, your CPU should never be the bottleneck in a gaming system.
A large number of posts don't make me an expert either Joker3. I'm learning just like everyone else here. I think before DSO offered their stage 3 air cooling, it may have been a different story, but in the right case, and by "the right case" I mean the 850i, stage 3 air cooling is highly effective.
The only gripe I have, is the lack of a 120mm based CPU HSF. The 92mm AC Freezer 7 Pro, is fine for stock speeds on quad cores, and for even overclocked core2duo's, but it struggles a bit with an overclocked quad in my experience. Something like the Xigmatek HDT D-1264 would be a nice addition to the air cooling selections. Toss an S-flex on something like that, and you'd see some dramatic differences.
The nice thing about DSO is they do honor special requests.
When you add in GPU's the cooling question becomes a little more complex, but the single best way to ensure that the entire system keeps it's cool, IMO, is to select video cards that do not recirculate the hot air inside the case. This means selecting an 8800GTS over a GT for air cooled applications for example.
Again, I'm *not* an expert, just another guy with the urge to surf the net, read, and share what I learn.
Edited by Tyler Lowe - 05 Mar 2008 at 12:36pm
Glenn-HI View Drop Down
  Quote Glenn-HI Quote  Post ReplyReply bullet Posted: 05 Mar 2008 at 2:12pm
Anything in the top 10 would work for air overclocking. Exclamation
  Quote Joker3 Quote  Post ReplyReply bullet Posted: 06 Mar 2008 at 6:17pm
Hey dog Lover, is "Thermoelectric Liquid Chilled" enough for cooling with 2 8800gtx? you don't use any fans at all? Becuase I thought "Thermoelectric Liquid Chilled" only cooled your cpu.
This page was generated in 6.835938E-02 seconds.
