Water cooling with distilled water.
Post Date: 2022-09-18
RickDanger View Drop Down
  Quote RickDanger Quote  Post ReplyReply bullet Topic: Water cooling with distilled water.
    Posted: 18 Sep 2022 at 10:25pm
Is it possible to use only distilled water and a couple bottles of primo chill utopia in a loop? I just flushed my loop and the seeing how the red dye stained my reservoir and blocks - can’t imagine it’s good for the internals of the radiators. I have an Aventum 3 running all copper.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 22 Sep 2022 at 12:48pm
It is possible to use distilled water as long as you add anti fungals, anti corrosions and the corresponding chemicals do not react negatively with the metals in your loop. The best to answer your doubt is the maker of the concentrate or additive.
I use clear coolant from EK and never have had an issue.
Good luck.
