Water Or Not 2 - Dont hijack please...Post Date: 2011-03-26 |
Author | ||
Ironwolf1974
Groupie Joined: 23 Mar 2011 Online Status: Offline Posts: 109 |
Topic: Water Or Not 2 - Dont hijack please... Posted: 26 Mar 2011 at 11:24pm |
Ok after reading reviews, webpages, taking peoples advice I put this config together.
Tell me what ya think.
ironmb
Senior Member Joined: 18 Feb 2011 Online Status: Offline Posts: 506 |
Quote Reply Posted: 26 Mar 2011 at 11:46pm | |
I'm pretty sure we already stated that it depends.
Clearly since you chose to go with stage 2 overclock, then yes liquid cooling. /end
Nebidimka
Newbie Joined: 14 Jan 2011 Online Status: Offline Posts: 84 |
Quote Reply Posted: 27 Mar 2011 at 12:14am | |
You need Hailstorm case, stage 6 wont fit in assasin
Quote Reply Posted: 27 Mar 2011 at 1:19am | |
that build is all wrong man, for LC you want more room then assassin.
corsair ram will make no difference. the intel ssd you have chosen is not a good one, and not one we recommend here. fan upgrade is loud and not needed, specially in LC setup. the gpu boost here is so mild you will see no difference from it. os boost has no baring on apps and game speeds. I assume we already talked about sli 570 vs 580. |
Ironwolf1974
Quote Reply Posted: 27 Mar 2011 at 8:37am | |
Yeah. Ok so I went a little over board.
Still a little confused over my first post I suppose, since it got locked.
So hailstorm case, no corsair ram, no SSD, unless of course they offer the Series 3 in early may when Ill be ordering.
Dual 570s over 580s.
What about the proc overclock?
Im not sure I want the hailstorm case, its pretty huge is it not? Over the assassin?
Is there a build like this that would include one of the HAF cases? I really like those.
Ironwolf
Alex
Quote Reply Posted: 27 Mar 2011 at 2:39pm | |
The Assassin isn't really an ideal chassis for our Sub-Zero Liquid Cooling system; it's more for air cooling. If you would like to build a system with our Sub-Zero Liquid Cooling, you can definitely do it with the HAF X.
Quote Reply Posted: 27 Mar 2011 at 5:54pm | |
if you putting LC on cpu then I would go stage 1 oc if not stage, with instructions to go with the highest oc with vcore lower then 1.42 if you putting LC on cpu and gpu then you want a big case cause there is lot of stuff that go in there and the tubes need room to move around, with LC you want smooth curves not sharp ones,m they effect the flow of liquid. IF you want LC on gpu and gpu with a HAF case then yes you can get it, I would feel more comfortable with a little sturdier case when it comes to full LC, and I love the HAF myself, if look you see for air cooled system or just LC on cpu, I recommend the haf x case to everybody with the extra fan on top for total of 4 x 200mm fans.
exactly, but its your money and your case so if you want to dish out more money for the little extra performance of the 580, go ahead, remember I'm just providing info, but IMO with your budget, I would go sli 570, with a gpu upgrade in 2 or 3 years. Edited by DST4ME - 27 Mar 2011 at 5:56pm |
Ironwolf1974
Quote Reply Posted: 28 Mar 2011 at 5:29am | |
Ok so how about this, mind you Ill be ordering early May, so they might have the gen 3 SSD which this machine leaves plenty of room for in my budget.
Quote Reply Posted: 28 Mar 2011 at 2:35pm | |
that looks good I would drop gpu oc, its very mild and you won't notice any gains from it, the OS boost makes no difference in apps/games speeds and with today's computers you don't notice anything from the os boost anyways.
I see you picked white tube with green light, and the case has a red led fan upfront, you ok with that mix? is so then you are good Edited by DST4ME - 28 Mar 2011 at 6:50pm |
Ironwolf1974
Quote Reply Posted: 28 Mar 2011 at 6:23pm | |
Oh yeah didnt notice that, so go with black tubing and red lighting or something of the effect hehe.
Yeah its free though, so mine as well go with it.
The HAF X is in same league as the hailstorm?
Quote Reply Posted: 28 Mar 2011 at 6:53pm | |
you can't compare the 2 cases, the hailstorm is more expensive and for a LC system is pretty great, for a air system not my cup of tea, for air cooled system I like the haf x and all the airflow you get.
the tubing is uv, in order to get the uv part of the tube to react, you need to get uv lighting, the green/blue/red lights, are not uv. its best to bo with uv lighting when choosing uv tubes. you can always change the haf's 200mm non led fans with 200mm red led fan Edited by DST4ME - 28 Mar 2011 at 6:53pm |
Ironwolf1974
Quote Reply Posted: 30 Mar 2011 at 6:07pm | |
Is the Hailstorm a sturdier case then the HAF X?
Ive noticed some plastic facing, fan mounts etc.
Just wondering which case would do better being shipped multiple times.
Also just water cooling on the CPU would be ok? For upgrade of video later. Since the CPU should be fine for several years correct?
Ironwolf1974
Quote Reply Posted: 30 Mar 2011 at 6:21pm | |
I also went the route of ordering that 30 IN dell with the insane resolution. Higher then what Im doing now, so would I see a difference with tri 570s?
Thanks for all the help.
Quote Reply Posted: 31 Mar 2011 at 1:23am | |
Hailstorm is much sturdier than haf x.
If your res is gonna be 2560 x 1600 with the u3011 (what an amazing monitor btw) then I would go with cf 6970. for some reason I can't load any builds right now, if I remember correctly you went with a SB build with 1000w psu and deluxe mobo, that system can't properly do sli, you will lose lot of bandwidth. |
Ironwolf1974
Quote Reply Posted: 01 Apr 2011 at 7:29am | |
Whats the best Mobo for SLI?
Should be getting the monitor next week, then first of May will order the computer.
Hopefully they have next gen SSDs in.
Can you raid SSDs?
Thanks for all the help so far.
Quote Reply Posted: 01 Apr 2011 at 4:28pm | |
Yes you can raid them but I believe you lose trim support.
for dual sli in SB I like the deluxe. My pleasure |
Ironwolf1974
Quote Reply Posted: 01 Apr 2011 at 4:57pm | |
Ok so just get the biggest one I can find, or maybe one smaller one for OS and one big one for my huge Steam game folder hehe.
I put the deluxe on all my computers that I put tgether. I likethat one alot.
Whats the maximus IV one got over the deluxe thats 190 bucks more?
Quote Reply Posted: 01 Apr 2011 at 5:07pm | |
Not sure some to be honest, some features for oc and perhaps more connectors for some stuff.
you can always get a 120gb 320 ssd for os/apps/some games and a second separate ssd for just games, kinda like this: HDD1 = 120GB intel 320, os/apps/some games HDD2 = 160GB intel 320, games/games/and more games HDD3 = 1TB black caviar for storage. if HDD2 gets full you can always add another ssd as HDD4 for more games again. in this senario there is no raid. or you can just get 2 x 160gb intel 320 ssd in raid 0 for 320GB worth of space, faster speeds, tho if one ssd goes bad, you lose everything on both drives. Edited by DST4ME - 01 Apr 2011 at 5:07pm |
Ironwolf1974
Quote Reply Posted: 06 Apr 2011 at 6:24am | |
516756Looking at this build as final. Unless the newer SSD's come in.
Quote Reply Posted: 07 Apr 2011 at 1:38am | |
If thats what you like, I would go with the regular haf x, and drop the gpu and os boosts.
the newer ssds are out, DS does not have them. |
Alex
Quote Reply Posted: 07 Apr 2011 at 2:11am | |
We do now!
Quote Reply Posted: 07 Apr 2011 at 2:42am | |
Crap I missed it, till now,
