What are they using?
Post Date: 2013-02-19
Brandon View Drop Down
  Quote Brandon Quote  Post ReplyReply bullet Topic: What are they using?
    Posted: 19 Feb 2013 at 5:33pm
I was curious about something and I was looking around on past threads but couldnt find anything. Lets use the Aventum as an example. What kind (brand) of fittings and bolts and tubes and waterblock rad systems are being used? I keep hearing about this EK brand and some others that are top notch etc, is there anyway to find out what brands DS is using?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Feb 2013 at 9:44pm
EK is great but not for everything this goes for most LC parts.
in the froshchill the rad and wb are not the best, but from subzero you get into the good stuff, the WB and rad for example in subzero are one of the best performers, the wb is Swiftech APOGEE XT Waterblock which is top 3 if not number one, I have this block in my system, the rad is xspc which is ok but if I get xpsc rads it would be the "Rx" series only cause those are great, not sure if DS is using the "RX" series or not, but if they are not I would ask that they use that in mine.
fittings and and etc, I'm not sure, probably a mix of different brands. pumps are swiftech, and I think tube is feser not sure.
EK has great water blocks for gpus, depending but xspc has some great gpu blocks also.
Edited by DST4ME - 19 Feb 2013 at 9:44pm
  Quote Brandon Quote  Post ReplyReply bullet Posted: 20 Feb 2013 at 5:43am
Ok so heres another question then, so Aventum being their flagship PC, it doesnt offer the Subzero LCS setup, but it offers the Cryo tech, and the H2O, so logic would generally think, the systems that are cheaper than the Aventum use cheaper cooling setups. But I have no idea if thats true, you mentioned the Subzero LCS uses the best WB and Rad, so if those are the best then what the hell is in the Aventum?
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Posted: 20 Feb 2013 at 6:10am
The h20 cooling in the aventum uses the same components as stage 6 as far as I know
  Quote Brandon Quote  Post ReplyReply bullet Posted: 20 Feb 2013 at 6:16am
@ Alex can we get a confirmation bud?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Feb 2013 at 3:41pm
Thats very simple.
cryotech is thermo-electric coolling and only for cpu, the gpus in Aventum are cooled with subzero.
Just to clarify I said if they use the xspc "Rx" series in the subzero then its has one of the best rad, for subzero I see its says they xspc rad but it does not specify what series and from the pics it does not look like an "RX" series rad, but I could be wrong about that, which is why you should ask DS if its "Rx" series or not, and if not then request the "Rx" series if you know whats good for you/your loop.
  Quote Brandon Quote  Post ReplyReply bullet Posted: 20 Feb 2013 at 3:48pm
I called DS and it is infact the XSPC RX series.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Feb 2013 at 3:58pm
Then there you go
but why are they using a different rad in the pic?
this is an 240mm RX rad:
Edited by DST4ME - 20 Feb 2013 at 4:05pm
  Quote Brandon Quote  Post ReplyReply bullet Posted: 20 Feb 2013 at 4:03pm
I honestly dont know we will have to wait for Alex to chime in and give us an answer, btw 20 mins left on my upload for the unboxing and review of my system :-)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Feb 2013 at 4:06pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 20 Feb 2013 at 6:06pm
To be honest it really depends on availability, we use a lot of top brands for our systems. It's hard to say what each component will be as every build is different. However, in general, we do use the best components possible.
