Which parts are easily upgradable?
Post Date: 2019-03-05
cmriboldi View Drop Down
  Quote cmriboldi Quote  Post ReplyReply bullet Topic: Which parts are easily upgradable?
    Posted: 05 Mar 2019 at 6:41am
I see that the chassis says that multiple parts of the rig are easily upgradable and customizable. Obviously the graphics card, RAM, HDD and SDD would be included in that, (which I see from the demo video).
But what about other more difficult to upgrade parts of the PC like the CPU or the Motherboard? Are those parts also easy to upgrade in the future?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Mar 2019 at 6:58am
Every part in the case is easily upgradable, depending on your skill set.  You can gut the case and install all new parts if you wanted.
Ram and the graphics card are the easiest, being plug and play for the most part.  The mobo and cpu takes a little more effort and skill, the mobo needing everything removed and installed into the new board.  Plus there is usually some setup other than plugging it in to finish the install, like making adjustments in the Bios, etc.
Big%20Smile
  Quote cmriboldi Quote  Post ReplyReply bullet Posted: 05 Mar 2019 at 7:55am
Nice. Doesn't sound too bad. :) Thanks for the quick response!
