Wifi built in
Post Date: 2023-01-30
Hort View Drop Down
  Quote Hort Quote  Post ReplyReply bullet Topic: Wifi built in
    Posted: 30 Jan 2023 at 4:10pm
Hey gang,
I -think- I know the answer but as my last custom build is several years old, I've never dealt with this and the way it's described in the product description and a few comments in other forums leave me unsure.
The ASUS ROG Maximus Z790 Hero, the wifi and bluetooth functionality is built in, yes? No additional network hardware/antenna needed?
Onboard LAN
LAN Chipset     1 x Intel 2.5Gb Ethernet
Max LAN Speed     2.5Gbps
Wireless LAN     Wi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
* WiFi 6E 6GHz regulatory may vary between countries, and function will be ready in Windows 11 or later.
Bluetooth     Bluetooth v5.2
Edited by Hort - 30 Jan 2023 at 4:12pm
fwfdfireman View Drop Down
  Quote fwfdfireman Quote  Post ReplyReply bullet Posted: 30 Jan 2023 at 6:29pm
Yes, no other hardware needed. In your Parts box when your PC arrives there will be an antenna you attach to the rear of the PC where all your USB connections are.
Old Gamers Never Die!
MrCheetah View Drop Down
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 31 Jan 2023 at 10:55am
Elaborating on what @fwfdfireman said...
There are two versions -- I do not know which the Maximus includes:
It has a 180-degree tilt adjustability and a magnetic base
This one require a bit of assembly and it's a little confusing if you only use the Asus documentation. Thankfully, someone posted a simple assembly demo:
Assembling an ASUS 2x2 dual band Wifi Antenna | djp3 (YouTube)
You'll connect the antenna wires to the two coaxial-type connectors between the USB and audio ports. Either wire can go to either connector.
Hort View Drop Down
  Quote Hort Quote  Post ReplyReply bullet Posted: 31 Jan 2023 at 11:55am
Thanks gentlemen! Much appreciated.
Hort View Drop Down
  Quote Hort Quote  Post ReplyReply bullet Posted: 31 Jan 2023 at 11:57am
That's what happens when you let a marketing/designer play engineer. ;)
