Will The Corsair LCD Display Cooler fit my Lynx?
Post Date: 2021-11-20
RaijinShedo View Drop Down
  Quote RaijinShedo Quote  Post ReplyReply bullet Topic: Will The Corsair LCD Display Cooler fit my Lynx?
    Posted: 20 Nov 2021 at 12:58pm
I have a Lynx level 2 and am wondering if i can fit the Radiator+240mm fans in the top portion of my case since it doesn't look like there is a lot of space over the ram sticks for them so wanna make sure it will work
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 20 Nov 2021 at 4:18pm
The Lynx case is a standard ATX size case. Specs say it can take a 240 mm radiator up top, or a 280mm or 360 mm radiator in front. The lead photo photo on the DS Lynx page shows a 240mm AIO cooler installed. A 240 mm uses 2 x 120 mm fans. A 280 mm would use 2 x 140 mm fans, and a 360 mm would use 3 x 120 mm fans.   Hope that helps you sir.
https://www.digitalstorm.com/img/products/lynx/2021-hero-image-2.jpg
