Will the Lumos case fit a 3070?
Post Date: 2020-09-08
kozmonaut View Drop Down
  Quote kozmonaut Quote  Post ReplyReply bullet Topic: Will the Lumos case fit a 3070?
    Posted: 08 Sep 2020 at 2:55am
Hey, looking at the inside pictures of the Lumos, big graphic cards are pushing against the edge of the case and some transistors on the motherboard.
Will the Nvidia 3070/3080 fit in a Lumos case?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 08 Sep 2020 at 4:07am
Serious? The big graphics cards are up against the I/O shield and fastened there so the cable ports can be accessed. On the side that counts, I see 2-3 inches from the cards to the radiator fans.
If it didn't fit, DS couldn't sell it to you is my guess.
Stellar View Drop Down
  Quote Stellar Quote  Post ReplyReply bullet Posted: 08 Sep 2020 at 8:23am
No clearance issues here.
SnowandSand View Drop Down
  Quote SnowandSand Quote  Post ReplyReply bullet Posted: 13 Sep 2020 at 4:08pm
For the most part most cards will fit no problem in most mid-tower cases and up... There are some exceptions like my EVGA RTX 2080Ti FTW3 card that is much larger than stock and in some cases it has to be mounted in a vertical mount (for some crazy reason it also won't mount horizontally on the Gigabyte X570 Master board lol)
Hailstorm II(Retired)
R7 2700x
16GB Team Dark Pro @ 3200 CL14
Asus x470 CH VII Hero
Corsair Hx1000i 1000W PSU
250GB Samsung 850 EVO
1TB & 6TB WD - Black Edition
2x GTX 980TI Strix
Hydrolux Stage 3
netranger6 View Drop Down
  Quote netranger6 Quote  Post ReplyReply bullet Posted: 26 Sep 2020 at 10:28pm
2070 super in a lumous. Asus Hero viii mobo. AIO stage 2 cooler. All is good.
This page was generated in 6.689453E-02 seconds.
