Wireless Card
Post Date: 2007-09-22
Willbig View Drop Down
Guest
Guest
  Quote Willbig Quote  Post ReplyReply bullet Topic: Wireless Card
    Posted: 22 Sep 2007 at 11:51am
I am going to have to order a system with a wireless card installed. Does this mean that when i go back to using wired connection i will need to replace with another card? Or will there still be a way to plug in a network cable?
ItalianPker View Drop Down
  Quote ItalianPker Quote  Post ReplyReply bullet Posted: 22 Sep 2007 at 8:18pm
No you won't need another card for a wire connection. Most motherboards, if not all, come with a network jack.
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 22 Sep 2007 at 11:02pm
The 680i SLI motherboard has two 10/100/1000 Megabit Ethernet ports on it. I believe that the SLI LT motherboard may only have one. If you have a wireless NIC in the computer, you could use the wired and the wireless connections simultaneously. The OS has to be configured properly to do this of course, but it's no big deal.
