Working on a quiet photo and video solution.
Post Date: 2013-09-19
bigkeith View Drop Down
  Quote bigkeith Quote  Post ReplyReply bullet Topic: Working on a quiet photo and video solution.
    Posted: 19 Sep 2013 at 2:46pm
Okay, I've been lurking on this forum for a bit. Trying to get a handle on a new system. Well now it's crunch time and I am really impressed with the community support here at DS so I thought I would throw this build out there. I am flipping between the GTX 770 or the 780. Researched the heck out of this. I did like a lot of the aspects of Arwen's build but I was unsure of the noise factor. Also unsure whether to go with 1 512GB SSD or 2 256GB SSDs as separate disks. 1 for OS and software the other for a scratch disk. Also I might add if a fan upgrade to PWM fans would help in the noise area?
$3000-$3500
Looking for a quick editing system that I can game on as well.
Use the Adobe CS6 suite. Pretty heavy photo editing. Moderate video editing and mostly RTS gaming when I game.
Looking for a performance but quiet build.
Saved Ticket #:
872589
Motherboard: ASUS Sabertooth Z87 (Intel Z87 Chipset) (Features Thermal Armor and Thermal Radar)
System Memory: 32GB DDR3 1600Mhz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
Power Supply: 750W EVGA SuperNOVA Gold Rated (Dual SLI Compatible)
Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST)
Storage Set 1: 1x (512GB Solid State (By: Samsung) (Model: 840 Pro Series)
Storage Set 2: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Graphics Card(s): 1x NVIDIA GeForce GTX 780 3GB (Includes PhysX) <b></b>
Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) <b></b>
Airflow Control: - No Thanks
Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material)
Windows OS: Microsoft Windows 8 (64-Bit Edition)
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large)
  Quote Alex Quote  Post ReplyReply bullet Posted: 19 Sep 2013 at 3:22pm
Thank you for considering Digital Storm, we would love to have you as a customer!
I would recommend having a dedicated SSD as a scratch disk if possible (especially if you are going to have data that you will be working off from on the same SSD as your OS/programs).
A GTX 780 is going to give you a bigger performance boost, so it might as well be worth it.
For the best airflow/noise control, I highly recommend getting our HydroLux control hardware and software.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Sep 2013 at 4:10pm
90% of your noise is gonna come from gpu's fan when under load.
the gpu has the smallest fan and the smaller the fans the louder they are.
Ticket Number: 872605
its not about whether there are fans, its about are the fans quiet or not, the parts in my ticket are quiet because they have quiet fans.
I can show you a noisy Liquid cooled system or I can make the same system very quiet but keep the performance.
best hdd setup is this:
to that you can always add more hdds or ssds if needed very easily, if you need help we can walk you thru, it would take 2 minutes flat.
As for gpu, I didn't catch what the pc is used for so I can't tell you if you will benefit from the 770 or 780.
sorry just saw that you want a photo video pc so in that case if the apps you use are gpu intensive get the 780, if not and your apps are cpu intensive then look at a 6 core cpu and a 770.
Edited by DST4ME - 19 Sep 2013 at 4:26pm
  Quote bigkeith Quote  Post ReplyReply bullet Posted: 19 Sep 2013 at 4:14pm
Thanks for the reply Alex. When I was researching the motherboards I choose the Sabertooth for the temp probes as well as the 4 pin fan headers. So I guess the dumb question is what does the HydroLux system provide that the Sabertooth doesn't? Would it still need a fan upgrade to PWM capable fans?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Sep 2013 at 4:22pm
HydroLux is a LC system.
LOL does nobody else see my post
Edited by DST4ME - 19 Sep 2013 at 4:22pm
  Quote bigkeith Quote  Post ReplyReply bullet Posted: 19 Sep 2013 at 4:36pm
Thanks for the reply DST4ME. I do like the build you gave and I had one pretty close to it but I was a little concerned with the noise level. 95% of the time I figured the noise of the HAF X would be marginal at best but I was concerned with the audio mixing/dubbing part of the video production. Edit: I realize that 6 cores are better than 4 but I liked the onboard memory controller and other features of the Haswell CPUs. So I figured the Haswell update would seem blazing fast compared to the P4 of my current system!
Edited by bigkeith - 19 Sep 2013 at 4:39pm
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 19 Sep 2013 at 5:29pm
A 6 core Intel CPU would be only on the Extreme processors, which would be Ivy Bridge-E for the newest one. These are one generation behind the Haswell for architecture. The Extreme processors also have the memory controller on the CPU along with 2 additional memory channels. So, more memory bandwidth. These use a different CPU socket, so it would need a different motherboard.
One issue with these motherboards is that the PCH (platform control hub), only has two SATA 3.0 (6bgps) ports and no USB 3.0 onboard. OEMs have added more of those on some boards, but will have a bit higher latency.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 19 Sep 2013 at 11:20pm
Alex was just recommending the controlling board & software of the Hydrolux system - not the full water cooling setup. This system just has the ability to also control the aspects of a water cooling system (although might seem like overkill for just an aircooled setup?). This would differ with the Sabertooth as to the possible number of controlled fans one could run. As DST4ME mentioned already, the HAF-X case runs cool & quiet because it uses larger fans running at slower speeds. Don't know if a separate fan controlling system would be really necessary with the HAF-X or not. Also the Noctura would be a lot more reliable than a closed loop water cooling setup.
As far as the SSDs go, not sure how much speed improvement you'd see running dual 256GB vs single 512GB. If you work with larger files, the dual SSD could give some extra oomph on the OS/App side of things when data is being accessed simultaneously.
Go with the 780. Will work best both for games and photo/video editing.
Unless you're doing some super extreme photo/video work, the 4770K should be fine. It'll have a ton of power compared to your current P4 CPU.
Good luck with your build!
  Quote bigkeith Quote  Post ReplyReply bullet Posted: 20 Sep 2013 at 12:01pm
Thanks for all the input. I am kind of leaning on this particular build. Since the case only has three fans I figured the MB can do the lifting there. I was also entertaining the idea of replacing the stock fans with the Noctua NF-F12 PWM 120mm Case Fans. I realize I had to trade a bit more silence for an air cooled system but I didn't want to go with a liquid cooled CPU. Build #:872801
  Quote Alex Quote  Post ReplyReply bullet Posted: 20 Sep 2013 at 3:11pm
The HydroLux control board and software does not require PWM fans. Yes, you can plug the fans into the motherboard, etc... however HydroLux ensures we're able to control every case fan.
Both are good options.
  Quote bigkeith Quote  Post ReplyReply bullet Posted: 20 Sep 2013 at 4:33pm
That explains the HydroLux control board! Thanks Alex. But the emails I had going back and forth with John (who is a great help) have me considering giving up on the liquid cooled thing! Almost back to square one! Need to hunt down some other builds in the review forums!
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 21 Sep 2013 at 6:36am
How many fans headers on the board? Does it only do voltage drop or can it do PWM too? Does it provide an RPM monitoring as well? What is the maximum amperage it can handle?
Edited by danjw1 - 21 Sep 2013 at 6:37am
  Quote Alex Quote  Post ReplyReply bullet Posted: 21 Sep 2013 at 10:22am
The Slade has features that cannot support full on liquid cooling properly. You will have to make changes to a config to suit the case to ensure it is quiet.
However, I was trying to say that, you could get ANY case, and get our HydroLux control board and software, and you can make it very quiet. We plug all chassis fans into it, up to 20 fans of support.
  Quote Alex Quote  Post ReplyReply bullet Posted: 21 Sep 2013 at 10:23am
HydroLux uses four daughter boards that allow five fans each. Total fans are 20. It lowers fan speeds via voltage drop, not PWM so it is able to work with multiple different fans. It does not provide RPM monitoring. It can handle a ton of power, up to 20 high-performance fans.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 21 Sep 2013 at 5:05pm
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 23 Sep 2013 at 2:47pm
For custom water cooling pumps, are they also controllable by this system?
  Quote Alex Quote  Post ReplyReply bullet Posted: 23 Sep 2013 at 3:38pm
Not the pumps, just the fans.
