WoW Classic budget build help
Post Date: 2020-07-05
mrfatmongoose View Drop Down
  Quote mrfatmongoose Quote  Post ReplyReply bullet Topic: WoW Classic budget build help
    Posted: 05 Jul 2020 at 12:14pm
I'm extremely new to PCs, and have been playing WoW Classic off of a MacBook. I've been putting a lot of time into the game, and want to invest in a rig that'll run it flawlessly, with streaming capabilities. Are premade Lynx's the way to go given WoW Classic isn't a very graphics intensive game? While it suffice to stream as well
$1,200-$1,300 (including Windows 10 and monitor
Being able to stream and play WoW Classic at the highest settings.
WoW Classic Playing + Streaming
Any ideas?
John18 View Drop Down
  Quote John18 Quote  Post ReplyReply bullet Posted: 05 Jul 2020 at 5:05pm
The question I have for you is do you know that you won't be playing games in the next 3-5 years that won't need (or look better) in a larger system, or is WoW it?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 06 Jul 2020 at 4:10am
A Lynx Level 3 would be ideal for what you want on a 1080p (Hi-Def) monitor. You would not have to be concerned about upgrading a thing for several years no matter the game.
A Lynx Level 2 would do the job, but you may be looking to upgrade the RAM and the video card relatively soon for future needs.
If you are looking for a monitor, DS offers a very serviceable model here in the ASUS 24 inch VP248QG (75Hz Refresh) 1920x1080 at $139.
  Quote mrfatmongoose Quote  Post ReplyReply bullet Posted: 06 Jul 2020 at 2:59pm
Thank you! Actually ordered the Level 3 this morning. If I plan on running a dual-monitor setup (they would have different refresh rates), would that impact my decision? One monitor (low refresh) for productivity/streaming and the other for gameplay
  Quote hoserator Quote  Post ReplyReply bullet Posted: 07 Jul 2020 at 12:45am
Congratulations and welcome to DS. Awesome
There will be no issues with different monitors with different refresh rates or resolutions. I have a 2k and 1800 resolution monitors hooked up to 1 card. There is more area to cover so there might be some degradation but it will depend on the resolution of the monitors.
Good luck and enjoy.Big%20Smile
  Quote Cretae Quote  Post ReplyReply bullet Posted: 07 Jul 2020 at 3:55am
You'll be very pleased!
hoserator knows his stuff.
