XM15 battery life
Post Date: 2011-09-12
zhoeffner View Drop Down
  Quote zhoeffner Quote  Post ReplyReply bullet Topic: XM15 battery life
    Posted: 12 Sep 2011 at 9:59am
I've been kicking around the idea of ordering the DS XM15 laptop, level 2. About the only change I would do is the upgraded thermal paste and the Bigfoot Networks Killer Wireless-N 1103 wireless adapter.
Now on to the question- What kind of battery life can I expect from this setup? I am a full-time student so, if I can avoid it, I don't want to be tethered to a wall by my charger.
Thanks for your time,
Zach
Unlicensedhitman View Drop Down
  Quote Unlicensedhitman Quote  Post ReplyReply bullet Posted: 12 Sep 2011 at 6:35pm
What kind of hard drive or SSD do you have?
Digital Storm xm15 laptop
-15.6" (1366x768)
-Windows 7 HP 64-bit
-Intel Core i5 2.4 Ghz
-Nvidia GeForce 330GT 1GB + Intel HD w/ Nividia Optimus
-6GB DDR3 ram
-Intel 80GB SSD
-Intel Wireless N 6300
  Quote zhoeffner Quote  Post ReplyReply bullet Posted: 13 Sep 2011 at 8:52am
The standard 500GB 7200RPM drive.
  Quote Alex Quote  Post ReplyReply bullet Posted: 13 Sep 2011 at 3:13pm
I would say 5-6 hours if you aren't gaming not using the WIFI to stream movies/downloading.
  Quote zhoeffner Quote  Post ReplyReply bullet Posted: 14 Sep 2011 at 4:42pm
Awesome, thanks for the help. Would I get better battery life if I did order w/ an SSD?
  Quote Unlicensedhitman Quote  Post ReplyReply bullet Posted: 14 Sep 2011 at 5:40pm
It will give another 30 minutes to an hour. The battery life for the xm15 is around 3 hours to 5 hours.
-15.6" (1366x768)
-6GB DDR3 ram
-Intel 80GB SSD
  Quote zhoeffner Quote  Post ReplyReply bullet Posted: 15 Sep 2011 at 8:54am
So the SSD wouldn't be worth the purchase cost for the battery boost?
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 18 Oct 2011 at 12:48pm
I don't have the system in question, so I will refrain from any advice in regards to battery life. However, I would also take into consideration the performance boost you would get from the SSD, as well as the extension of battery life that UnlicensedHitman mentioned.
