XM15 battery/plugged in performance
Post Date: 2011-09-22
NOPE chuck testa View Drop Down
  Quote NOPE chuck testa Quote  Post ReplyReply bullet Topic: XM15 battery/plugged in performance
    Posted: 22 Sep 2011 at 9:47am
I almost always keep my laptop plugged in to its charger and I am concerned about the whole battery degradation issue. If I leave my laptop plugged in with the battery removed will there be any performance difference compared to leaving my laptop plugged in with the battery attached?
Thanks
Unlicensedhitman View Drop Down
  Quote Unlicensedhitman Quote  Post ReplyReply bullet Posted: 22 Sep 2011 at 12:28pm
Thanks
If you leave your laptop plugged in without the battery and with the battery, there is no performance difference.
If you have your laptop plugged in without the battery, you may lose the data when there's a power outage. If you're doing something important, you should have the battery attached just in case or you'll be Upset.
I mainly use my laptop plugged in with the battery attached, but so far, it only has degraded about 3% after a year of use. If there is no outlet available, then I'll use the battery.
Digital Storm xm15 laptop
-15.6" (1366x768)
-Windows 7 HP 64-bit
-Intel Core i5 2.4 Ghz
-Nvidia GeForce 330GT 1GB + Intel HD w/ Nividia Optimus
-6GB DDR3 ram
-Intel 80GB SSD
-Intel Wireless N 6300
