$3.5k Build Help
Post Date: 2015-01-02
Vizo View Drop Down
  Quote Vizo Quote  Post ReplyReply bullet Topic: $3.5k Build Help
    Posted: 02 Jan 2015 at 1:39pm
[$3,500]
[Tri-Monitor Setup (3x BenQ 27", SSD]
[Primarily gaming, streaming online content, minor photo editing]
So I bough a system from Digital Storm about 2 years ago, and now it's time for another. My current one is moving on to my wife, which means an upgrade for me!
Any help would be appreciated. I'm looking to run a 3 monitor setup (referenced above).
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 02 Jan 2015 at 4:08pm
So i made you a couple of configurations:
https://www.digitalstormonline.com/configurator.asp?id=1125802
https://www.digitalstormonline.com/configurator.asp?id=1125803
I left a little wiggle room for shipping/taxes and if you don't like the part choices you can change them.
Vizo View Drop Down
  Quote Vizo Quote  Post ReplyReply bullet Posted: 02 Jan 2015 at 6:20pm
Thanks!
In the first build (1125802), would subbing out the liquid cooling for the Notua make sense? I'm just not sure I'm to keen on liquid cooling. Can you convince me otherwise?
I'm also considering using 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX), rather than the 1x you had linked. In running a 3x monitor setup, would there be a noticable difference?
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 02 Jan 2015 at 9:35pm
The Noctua cooler will provide about around the same amount of cooling as the water cooler...so it is whether the chassis has the space to support either is the question.  Most of the cases DS uses can support the radiators with the water cooling (some may only support the 240mm rad, where others can handle the 280mm rad).  The Noctua on the other hand is more limited, and you can select it, but if it doesn't work with the case you've selected, after you've placed your order (but before they've processed it) they will contact you and work out a doable solution with you.
Yes, GTX 980's in SLI will have a noticeable impact with the monitors you've got.  They have a refresh rate of 144Hz, with is nearly 2.5x the rate of typical 60Hz monitors out there...and you have three of them no less.
Here is a configuration that will come within your price point after the promotion discount:
Configuration URL:     https://www.digitalstormonline.com/configurator.asp?id=1125978
Chassis Model: Special Deal Hot Seller - Digital Storm Coridium
Motherboard: ASUS MAXIMUS VII HERO (Intel Z97 Chipset) (The Ultimate Power Platform)
System Memory: 16GB DDR3 2133MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST)
Storage Set 1: 1x SSD (256GB Samsung 850 PRO)
Storage Set 2: 1x Storage (2TB Western Digital - Enterprise Edition)
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX)
Airflow Control: - No Thanks
Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection)
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
  Quote oldlady RPGer Quote  Post ReplyReply bullet Posted: 03 Jan 2015 at 1:06am
Hi Vizo just to chime in.
I have LQ on my big rig and LOVE it! It's nothing to change out the fluid etc. I will say that I do have medical experience with Tygon tubing so it's easy for me.
Oh and I like all the choices.
Edited by oldlady RPGer - 03 Jan 2015 at 1:07am
