Bolt II help
Post Date: 2015-03-14
Arkady View Drop Down
  Quote Arkady Quote  Post ReplyReply bullet Topic: Bolt II help
    Posted: 14 Mar 2015 at 1:47pm
Under $1700
Mostly strategy games like Rome:Total War II, Civ 5, Sim City, etc.
Special Needs: Considering the Bolt II because I do want something SFF. I also want it as quiet as possible.
Configuration Code:     1162969
It's the standard level 1 config with a liquid cooling upgrade and lighting taken out. Would the radiator help a lot with noise level? Should I consider the hydrolux control?
If I already have an external 1TB HD should I bother with the internal one? I was thinking I could wait sometime for SSD prices to come down and install a 2nd one later.
Thanks.
  Quote Alex Quote  Post ReplyReply bullet Posted: 14 Mar 2015 at 1:55pm
You don't need liquid cooling, but our Control Board option under airflow will help ensure you have a quiet system.
If you don't want to get a larger storage drive now, just make sure you get a large SSD, like a 250GB+
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 14 Mar 2015 at 2:11pm
I was able to get my Bolt II noise down substantially. Details are in my write-up, linked in my signature. And as for storage, you can use your own...which is what I did with a large SSD I had. SSD prices are already getting pretty low (relatively speaking) and they will provide the most noticeable light usage performance boost in a system.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 14 Mar 2015 at 2:50pm
Hi Arkady,
If a SFF case is your primary goal then you have a good build for this budget level. However, you are sacrificing performance in order to get the Bolt II case. There are better options for a quiet computer, more CPU power, more GPU power, a SLI motherboard and a bigger power supply within your budget.
Edited by FrankW - 15 Mar 2015 at 12:12pm
Pacesetter View Drop Down
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 15 Mar 2015 at 11:54am
I'd suggest using the internal HDD and use the external HDD for back ups.
With SFF you kind of limit upgradeability but this will handle your present needs nicely.
Vanquish II Ultimate.
  Quote Arkady Quote  Post ReplyReply bullet Posted: 15 Mar 2015 at 3:11pm
Appreciate everyone's input. Was considering building on my one but I'm a bit of a novice. With a SFF I'm just concerned about heat issues and ending up with something overly loud. This seems to be giving me what I need.
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 20 Mar 2015 at 1:16pm
For a small system...bolt is soo powerful!
I7 13700KF 5.4hz
ASUS Prime z790 MoBo
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
27" ASUS Monitor 144hz
Razer Ornata Chroma Keyboard
Razer Basilisk V2 Mouse
Nari Ultimate Headset
