HELP! What wires for dual screens?Post Date: 2015-03-23 |
nayots
Newbie Joined: 22 Feb 2015 Online Status: Offline Posts: 20 |
Topic: HELP! What wires for dual screens? Posted: 23 Mar 2015 at 5:38pm |
My Vanquish L4 just got here, and I was about to plug in my displayport into the video card but it doesnt fit. There are DP options, but they are much smaller. What do wiring do I need to set up my dual screens?
Quote Reply Posted: 23 Mar 2015 at 5:41pm |
You can get adapters for displayport to HDMI or DVI. The cards typically have 1 displayport, 1 HDMI, 1 DVI-D, and 1 DVI-I.
nayots
Quote Reply Posted: 23 Mar 2015 at 5:43pm |
Quote Reply Posted: 23 Mar 2015 at 6:16pm |
Different model gtx 970s have different video port config. You could have mini displayport. Check the accessory box that came with your rig for DP to mini DP adapter. You might have to get mini to full size adapters to run both monitors. Or hdmi to DP , etc like was said.
nayots
Quote Reply Posted: 23 Mar 2015 at 8:26pm |
Pacesetter
Groupie Joined: 19 Jan 2015 Online Status: Offline Posts: 379 |
Quote Reply Posted: 23 Mar 2015 at 8:39pm |
Your card may have a plug in the display port. check closely and just pull it to remove. Asus plugs theirs, not sure about others.
Make sure you are plugging in to the video card and not the built in graphics on the motherboard. |
Vanquish II Ultimate.
I was laying in bed looking up at the stars and wondered "where is my ceiling?" |
FrankW
Quote Reply Posted: 24 Mar 2015 at 7:53am |
Hi Nayots,
Your 970 GPU should have three DP 1.2 connections. As stated they may be mini-DP. I suggest you call DS and a technician will help you get setup correctly for two monitors. Frank |
nayots
Quote Reply Posted: 27 Mar 2015 at 2:09pm |
My DVI DUAL LINK wire works for either screen, I have DP wire with an HDMI tip + a adapter to Mini HDMI this is the one not being recongized. I've been calling tech support for a while, no asnwer :(
Pacesetter
Quote Reply Posted: 27 Mar 2015 at 8:45pm |
Did you try any of the suggestions on your other post?
Go to control panel - devices and printers and see if the monitors are listed there. If not, at the top click 'add a device' and follow the leads to 'find devices'. Then go to device manager - display adapters, and look for the Nvidia GTX970. Disable any others. Go to 'monitors' and make sure yours are listed. If it says "generic pnp monitor" - turn off computer and monitors, unplug all from the wall and unplug monitor cable from the monitor for 2 minutes, then plug in the monitor cable first, and plug in the power cords and boot up as normal. Then recheck the above. check device manager for any colored ! or ? marks which means something is wrong. Post back the results of what you did and what you found. Please try what we suggest and let us know what results you got. We are working blind as we must go just on what you tell us. The call to DS may be the best solution as they can log on to your computer with logmein and get to see what we can't. |
Pacesetter
Quote Reply Posted: 27 Mar 2015 at 11:42pm |
Try this also.
hit (windows key) + P. You should get a menu on the right to select PC screen only (screen1), duplicate, extend, and second screen only. What do you get? Can you select second screen only and get anything on that screen? |
