Need a lot of help, not sure what I need
Post Date: 2014-12-17
kisianik View Drop Down
  Quote kisianik Quote  Post ReplyReply bullet Topic: Need a lot of help, not sure what I need
    Posted: 17 Dec 2014 at 12:36pm
Hi.
This will be my first PC from boutique PC maker, before I was a Dell guy, but enough is enough.
Just want to mention, I have some experience with upgrading existing Dells far beyond Dell's expectations. I even used stronger CPU (I was first documented to do so with Inspiron 570), than Dell recommended, I was second (documented) to overclock this Dell, eventually moved all components into CM 912 HAF case with powerful AIR cooling.
I am hoping that I don't have to do that much here, but who knows. That is why I am here.
So, lets start.
My budget including monitor is $3000. Monitor will come from Dell, because I need 23" to 24" IPS one. Dell monitor will cost me about $300 or so - about $2700 left for PC.
Also, I need this PC to be able to play games on ULTRA to VERY HIGH settings for the next 3-5 years.
My interest is in FPS games like Far Cry series and BF series as long as hardware will support them. Not interested in any strategy games and any fast car games like Dirt and similar, so TN screen is not necessary, I think, also light video and photo editing will be involved (here comes IPS).
After long configuration games I settled more or less on:
Configuration#: 1117036
Chassis Model: Special Deal Hot Seller - Digital Storm Marauder V2
Motherboard: GIGABYTE G1.Sniper Z97 (Intel Z97 Chipset) (Onboard Creative Sound)
System Memory: 16GB DDR3 2133MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
Storage Set 1: 1x SSD (500GB Samsung 840 EVO)
Storage Set 2: - No Thanks
Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (EVGA ACX Cooler Edition)
Sound Card: Creative Sound Blaster Z
Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans)
Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material) <br><strong></strong>
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
Here comes a lot of questions, I will try to structure them with numbers for better responses.
1. What I can not do with the system to prevent voiding warranty, or what allowed to be self upgraded without loosing warranty, or what are the limitations of the warranty? I am mostly considering adding HDDs and fans in the near future and maybe second GPU for SLI in a year or so (when prices drop), if ever.
2. Question about the case. I could not find detailed description of the Marauder case, so I figured out that it is re-badged Corsair Vengeance C70 case (here I found all information I was interested in), is it completely so, or DS added some modifications or removed some features? I am very interested in dust filters and extra fans locations, also is upper HDD cage removable for better ventilation or not.
3. CPU. Is 4790 is future proof (3-5 years) for my needs, or I got too much and  4690 is more than enough, both would be moderately overclocked, more about overclock later down the road.
4. Motherboard (MOBO). I am not sure here, however I like my choice not just for overclocking, but also for 6 SATA (I don't want to add RAID card for extra HDDs) and architecture specifically locations of PCI (various ones) connectors. This GIgabyte has PCIEx1 slot right above PCIEx16 slot, dual GPUs in the mid ATX package take a lot of space... I know that this MOBO Creative Audio has some issues, so that is why dedicated Sound card is coming here. Suggestions welcome.
4. RAM. What is better, DS 2133 RAM or Corsair 1866 OC to 2133 and maybe above? Is DS 2133 overclockable, or it is not advised? Do I actually need faster than 2133 RAM?
5. PSU. I read somewhere that DUAL SLI GTX 970 (possible future upgrade/addition) would work with 750 watt, but 850 is preferable, is it so?
6. SSD. If i had more $$, I would go with PRO version, but I am not. I found a note on newegg that EVO 500 GB (maybe all EVOs) have problem overtime with old files, that speed of the system dropping significantly over period of 4-6 months, what DS has to offer here.  This is exact quote from newegg
"Cons: All of the Samsung Evo 840 Evo series seem to have a serious problem that degrades file access performance on files over 30 days old. Samsung recently issued its "Performance Restoring Software" to counteract this. However, be advised that this is an hour or more long process for a 500 GB SSD. And, it appears that this will need to be done about every 30 days or so to maintain performance. Most people don't want an SSD or HD that requires this excessively high level of maintenance each month, year in and year out. Avoid the 840 EVO series of drives."
Any comments about above statement (it is OK for me to run this software once a month for the price of PRO series if this is the only answer).
7. GPU. I seen somewhere in this forum that multiple manufacturers are used in this option, not only EVGA (pictured), is there a possibility to choose which one to install, or at least which one to avoid - I prefer personally ASUS or GIGABYTE, and avoiding ZOTAC and PNY with EVGA somewhere in between (I would like MSI, but I don't recall that you are using them). If it is possible to choose a specific one, could models be provided?
8. Cooling. I have to start from my location - which is about 5 hours drive from you guys, so it was very hot here last summer, ambient temperatures in my PC room reached 35 C for a few days and 33 C for a few weeks.
So in this situation, which cooling is the best (considering overclocking) Noctua or H2O 240 mm/280 mm versions? If no big difference AIR only is more sturdy over long time, I think. Suggestions, opinions...
9. Fan upgrades. Marauder case comes with 3 weak fans. What up to 6 fan upgrade means exactly, adding more, or changing 3 fans only for $99? If Marauder configuration is the same as Corsair Vengeance C70, there could be added 2 top 120mm/140mm (if AIR cooling), 2 front 120mm, 2 side 120mm and 1 bottom 120mm, which is equals 7 more fans. So, can you explain meaning of $99 upgrade please.
10. Digital Storm Thermal Management Control Board. Can not find exact specs yet. What it can support, can this Board support 7 more fans for the total of 10 fans, not including Noctua? And where it would be installed, would it take 2 5.25" bays?
11. Noise Suppression Package Stage 2. What exactly this means in terms of AIR flow adjustment, and how much dB approximately it will erase, say 10% or so, or even more?
12. Overclock CPU 4.0GHz to 4.4GHz. If I want to go higher would cheap cooling like 280mm Corsair would be enough in my location, or high clock will require $500+ cooling system?
I think I covered all my questions.
Appreciate in advance for all help and suggestions and opinions provided.
Thank you.
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 17 Dec 2014 at 2:55pm
1. Adding HDDs and Fans should not affect the warranty in any way.
2. Corsair Vengeance C70
3. 4790K and 4690K both work. You'll get hyperthreading and a little bit better clock on the 4790K. Gaming loads shouldn't be too terrible on a 4790K for the time being...this question is always asked and it will always be a question no matter the generation of processor. With the Z97, you do have the option to upgrade to Broadwell-K processors in the future if you would like.
4. Corsair will guarantee you decent latency timings, but the timings on the DS 2133 RAM may not be bad.
5. The system should be fine on a 750 unless you add things much beyond a dual GPU setup.
6. The performance restore can probably be done when you go to bed. It seems like Samsung did not do a good job with implementing TRIM on the drives and they needed to band-aid it up.
7. ACX will guarantee EVGA, as that is an EVGA cooler. You have to opportunity to talk with DS plenty as your order is being processed.
8. Air cooler should work just fine. If a fan fails on an air-cooler, it can still operate at lower loads without a fan running. The effects of higher ambient air temperatures will affect cooling solutions with smaller surface area greater.
9. They'll add Corsair Air-series fans; probably in all available fan slots, up to 6, I would guess (I didn't have that question with my Bolt)
10. It's a fan and LED controller board with a number of 3-pin fan headers and a customer software interface. They mount it on the back of the motherboard tray in the Hailstorm II; not sure how it will be done here...you can ask them.
11. Air flow adjustments are changing up the fan speeds in the BIOS (and perhaps in a software tool on the desktop, too; don't know). I have an ASUS board and it is pretty easy to do...there is a button and the motherboard does it automatically. Stage 2 I believe adds sounds damping material to the inside of the case to absorb sound pressure and vibrations, reducing the noise transmitted through the case.
12. A larger cooling surface will help with higher ambient temperatures.
In regards to your configuration, it looks good. I would definitely drop the sound card (the motherboard has the exact same audio processor on it), drop the airflow card and upgraded fans (get some cheap fan splitters and extra fans), and add a dual GTX 970 with blower-type coolers (reference design; you won't be able to specify the brand, but DS has excellent support). I'd allow DS to configure the computer with the SLI configuration if you're going to do it and if you're spending this much on a computer, you should probably get it straight away. This should be close to you target of $2700, but if you want to get closer, you can drop the PSU down a little to, that'd be up to you.
  Quote kisianik Quote  Post ReplyReply bullet Posted: 17 Dec 2014 at 5:53pm
Thanks
I really appreciate for fellow consumer opinion, but it would be nice if someone from DS could jump in and answer those questions, especially ones related to case cooling and case features, otherwise I would have to do what I am trying to avoid - customizing final product.
I am trying to even out all questions in smooth conversation prior jumping with all of it on the head of configuration assistance person.
From my previous experience, manufacturer's forum mods are usually equal or exceed in knowledge compare to configuration assistants.
For an example. I seen somewhere here that more customized options especially related to GPUs are possible. If I could see at least list of possible models in advance, I would narrow down my choices through outside reviews, taking my time. I hate last minute rash decisions here.
So, anyone else can add something?
Official help deeply appreciated.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 17 Dec 2014 at 6:45pm
Other than Alex and Nav, none of the DS employees comes on here.
You can shoot Alex an email at [email protected] unless of course he pops on here later
  Quote Alex Quote  Post ReplyReply bullet Posted: 18 Dec 2014 at 7:41am
Hi,
First off, thank you for choosing Digital Storm, we would love to have you as a customer. My responses to some of your questions are below, if you would like to reach me directly, you may email me "[email protected]" or you may call in and speak with our team.
Thanks!
1. You're free to make changes to the system and upgrades, that will not void your warranty. However, what will void your warranty is physical damage to components from changes or upgrades you make on the PC. Adding HDDs and fans and other components is perfectly fine.
2. It's the Corsair C70
7. If you want a specific GPU, we do offer certain brand options already. If you want us to special order a card, we can do so as well.
9. You don't really need to add a ton of high-airflow fans. Components are designed to work well without the need of them running really loud with high RPM fans.
10. We can control up to 16+ fans with the control model if needed. However, we don't plug the CPU fan into the module as it's not related for airflow control, that's the CPU. The CPU fan is best left connected to the motherboard so we can control it's speed directly.
11. It's hard to say on this, what I can say is that we slow th fans down with resistors and adjust BIOS settings to make your system as quiet as possible.
12. The 280mm Corsair liquid cooler should help with higher overclocks above 4.4GHz, however we won't know for sure on your custom build until it goes into testing.
  Quote kisianik Quote  Post ReplyReply bullet Posted: 22 Dec 2014 at 3:24pm
Thanks for all replies.
I am actually is trying to reach sales person now on phone, as chat is not pop in up, to ask for final clarifications.
I would be happy with 6 fan package if they are installed in the right spaces, however I don't know the upper clearance of Noctua (I checked multiple sources and Noctua is equal or wins in majority comparisons against h100i or h110) before the upper mesh of the case, and clearance between side door and top of Noctua.
And the last question still remains with GPU selection, as I want to avoid at all costs blower versions and EVGA everything.
Now it is all about the contacting DS via phone.... answering machine only.
Thanks again.
  Quote kisianik Quote  Post ReplyReply bullet Posted: 22 Dec 2014 at 10:28pm
Update.
Spoke to sales, got very disappointing news.
First, Noctua doesn't fit. I kinda was expecting something like this, so I took it easily, but next thing frustrated me a lot. There is a choice in configuration for H110, which is 140 mm radiator. DS stated that it doesn't fit, only H100i fits. I look at Corsair site for compatibilities and found that H110 is on the list Excited
Look at this video, https://www.youtube.com/watch?v=y0VfiDHgk4g (can not hyperlink, sorry) this is very strange, why not. No special modding at all, it is a quick job when done by professionals.
Regarding video card. I was told, after prolong conversation, that there is a choice of ordering different cad, the ordering option is $40 for service only plus the difference in price. This can be found only upon ordering and sales/assembly will contact me on this, once I made my purchase. I would prefer to do preliminary estimate prior to purchase - I really don't like to do things under pressure (during actual assembly). So far I found only MSI GTX 970 Gaming 4G to be very close in terms of pricing (I approximated price of EVGA ATX version, MSI just about $10 or so more on newegg) and performance to my needs and budget.
Also, a big surprise - Noise Reduction package "doesn't fit" not even package 1Question, which is only fan optimization, no hardware added. I do suspect that sales fallen far behind actual assembly people in terms of actual hands on knowledge (that was also manifested during all conversation), I know, I came prepared for conversation, but I did not expected this at all.Upset
Overall, I expected more from sales.
I will attempt to do a bit more finalization tomorrow before actual ordering.
Any suggestions?
Edited by kisianik - 22 Dec 2014 at 10:29pm
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 22 Dec 2014 at 11:42pm
From my experience, if you put anything in the Build Comment section of the order form, they will get a hold of you before the order is processed and get everything squared away. After you get all the details determined, then the order is processed and the build begins.
If the H110 fits, I would show them the info you referenced and see if they come back with anything (I can't really think of how the can refute it; the only thing I can think of is if all drive bays were full and that caused an interference of some sort).
As for noise reduction, if you went with an ASUS board instead of a Gigabyte, and drop the noise reduction package. ASUS has an excellent automated fan optimization routine built into their BIOS and can get the noise down quite a bit. Right now with Gigabyte, you can only specify a linear rate at which the fans respond to temperature.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 8:24am
Hi kisianik,
You seem to know what you want and I don't want to interfere with you getting your system. But, I think you are limiting your choices with the Marauder case. You can get the Apollo case, another Corsair case, for $52 more than the Marauder. The Apollo case will take the D14 or the H110. In my opinion the only thing the Marauder has going for it is the cost.
I suggest you consider dropping your SSD back to the 256 Pro instead of the 512 Evo. This will solve the problem with the Evo long term problem. Add a 1TB WD black HDD for storage. If you later need more SSD storage you can add one yourself.
Here is a suggested system with the above thoughts in mind. It has better cooling, better GPU, better mother board and better, but smaller SSD.
Configuration: 1120155   Cost: $2783
Chassis Model: Special Deal Hot Seller - Digital Storm Apollo
Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components)
Storage Set 1: 1x SSD (256GB Samsung 850 PRO)
Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition)
Airflow Control: - No Thanks
Edited by FrankW - 23 Dec 2014 at 8:26am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 9:02am
I agree with Frank.  The case can be a very personal thing, but I wouldn't let it determine the guts that you might want.   The Apollo, Corsair 760t, is a nice case.    The Air 540 I believe would also fit the coolers you want.
The Sabertooth mobo is one of the most reliable, and its 5 year warranty vs 3 years for most others, shows the confidence the manufacturer has in it.
Good luck with your decisions and keep us updated.  Big%20Smile
  Quote Alex Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 9:39am
The case is a limiting factor because some of the hardware gets in the way with the builds. I know you might be in love with that style/design, I suggest that you may want to look into a different case that does allow you with more options.
  Quote kisianik Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 11:51am
OK, another update.
I like Apollo, too big, barely fits in my PC space under the cabinet table, but it is full ATX case.
So, this is almost final configuration: 1120240
Motherboard: ASUS MAXIMUS VII HERO (Intel Z97 Chipset) (The Ultimate Power Platform) <br><strong></strong>
System Memory: 16GB DDR3 2133MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) <br><strong></strong>
Power Supply: 750W EVGA SuperNOVA <br><strong></strong>
Storage Set 1: 1x SSD (500GB Samsung 840 EVO) <br><strong></strong>
Storage Set 2: - No Thanks <br><strong></strong>
Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (EVGA ACX Cooler Edition) <br><strong></strong>
Sound Card: Creative Sound Blaster Z <br><strong></strong>
Extreme Cooling: AIR: Stage 2: Noctua NH-D14 SE2011 Extreme Performance <br><strong></strong>
Airflow Control: Digital Storm Thermal Management Control Board & Software <br><strong></strong>
Here a few questions.
If I choose to stay with ASUS, do I need "Airflow Control: Digital Storm Thermal Management Control Board & Software" option, or Asus MOBO can manage all case fan temperatures for me? Or only Noctua and exhaust fan? I see that it has "4 x 4-pin Chassis fan connectors" so 4 additional fans only? Are Corsair upgrade fans 3 pin or 4 pin?
GPU. Thanks for offering GTX980, but I will have Dell H2412M IPS 1900x1200 monitor, GTX980 is way overkill, I decided to stay with EVGA GTX970 ACX, additional fans should cool it better in larger case. Newegg price is about $250 with almost free shipping.
Cooler. Now Noctua fits easily. I would go with AIR only to avoid maintenance in the future, plus it is more silent. And it is on par with H100i and just a notch worse than H110.
Hard drives. For cost I will go with 500 GB EVO and will install Samsung management program to take care of TRIM. I am currently typing on Intel 520 SSD 180 GB and using Intel manager all the time, so it will be Samsung manager. I have bunch of RED NAS WD 3GB and 2GB HDDs, some of which I am planning to migrate to the new case, as of now, I have no additional budget for extra HDDs.
This is about it
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 12:22pm
The gtx 980 isn't overkill. Some games on the highest settings can use the extra 15-20% better performance, but the 970 is better dollar per performance, the 980 pricier for the increase in fps.
Mobo software will only control the fans plugged into it.   The DS Control board can control up to 16 fans, I believe. The Noctua fan, one or both, would plug into the cpu_fan header so Bios or mobo can monitor it. I don't think controlling the Noctua fans will be needed. They are quiet and the air flow is best left as-is, imho.
The Apollo has a 2 speed front fan speed toggle and can take up to 4 fans. The fan speed is a 12vdc full rpm or a 7 vdc, or so, step down to drop fan rpm. Not variable beyond the 2 step.
Edited by bprat22 - 23 Dec 2014 at 12:26pm
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 12:49pm
Maximus VII Hero has:
1 x CPU Fan connector(s) (1 x 4 -pin)
1 x CPU OPT Fan connector(s) (1 x 4 -pin)
4 x Chassis Fan connector(s) (4 x 4 -pin)
You can put splitters on the headers and drive up to 3 fans off of them (don't use high power industrial fans, though; you can add more or use high power fans with supplemental power).
The chassis supports up to 7 case fans, so you should be covered as far as fan headers go with the motherboard and cases fan speed control if you wanted to have the maximum number of fans.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 12:59pm
Yep, the fans should definitely be covered.
  Quote kisianik Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 3:42pm
Thanks.
So be it. No extras cooling, all on Asus, thanks for "splitters on the headers" recommendations, especially since upper case fans should run at the same RPM anyway, and there are 3 of them. I just wondering what amperage those CPU fan headers support, where I can find it?  I am considering BGears b-PWM 120 Black Case Fan at local Fry's, only $13.99 and max CFM is 110 (if cooling will become an issue). I am using similar 120mm in my present build, not that loud at 100%.
My only concern is PSU, would 750 watt be enough for possible future dual SLI plus 4 more HDDs and all fans I can fit, or I have to go with 850 watt (I am trying to stay in $3000 limit with monitor, which is $250 at newegg or amazon).
I wish that DS could add U2412M for the same money to the mix, but I think it is too much (it costs at Dell $289).
This is set to go, except for PSU, any quick suggestions?
  Quote FrankW Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 4:05pm
Hi kisianik,
I think you have made some better choices in your last build. The D14 cooler is quieter than the H110 but the H110 cools better. There is no maintenance with the H110 unless the reservoir/pump/control fails and you have to replace it. The D14 has no moving parts and they both have fans to fail.
You mentioned about putting your computer into a space below your cabinet table. With your high temps part of the year you may have problems if the computer is in a closed area. Both the D14 and the H110 use ambient air to cool and you can reach a point that the cooling air blowing threw the coolers no longer cool well enough for full on gaming. I don't know your setup and suggest you be careful not to obstruct air around your computer. When you start getting into the 90+ temps cooling gets more difficult.
Good luck with your system.
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 4:15pm
Someone on the ASUS forums was saying 1A @ 12V for each header:
http://rog.asus.com/forum/showthread.php?52221-Multiple-Fans-to-1-Motherboard-Fan-Header&highlight=header+amps
You can usually find the max power draw in online specs for fans, and it is also usually on a sticker on the fan as well.
Oh, and you don't need a sound card. ASUS makes some of the best sound cards out there and over the past couple generations of motherboards they've been transferring the tech to the on-board sound.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 4:21pm
The 750 watt should do it, but I would keep your original EVGA 850 watt psu pick.   It has a 10 year warranty vs 3 years. Plus, extra headroom just in case. Psu with today's cards can be less than even 2 years ago, but for the little extra money, the psu is worth it for me.
Asus typically has a 1amp, 12watt, rating, on the fan headers so if that fan is .32 amp, then doubling up on a header should be fine. Something to check yourself, but that's been the general rating for awhile.
You beat me.
Edited by bprat22 - 23 Dec 2014 at 4:22pm
  Quote kisianik Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 4:49pm
Fan headers general question.
This motherboard has 4 pin headers, if I look around, majority fans have 3 pin, for an example corsair AF140 (DS uses AF120). Can those be connected directly to motherboard, or I have to look for 4 pin fans?
I am actually is ready to click purchase button, this is the only question remains.
Thanks all of you for suggestions.
This is my final configuration: 1120387
Storage Set 1: 1x SSD (512GB Samsung 850 PRO)
Comment request form:
I would like to change GPU to MSI GTX 970 Gaming 4G if possible and $$ acceptable. Can SSD be mounted to lateral location. Can PSU placed as exhaust, fan inside the case? Please provide all extra cables left from motherboard and GPU installation. Thanks.
This is it.
So last minute suggestion regarding 4 pin vs 3 pin is appreciated.Frustrated
Thanks again for all advices.
Ready to push submit buttonDrooling
Update, just found in Asus pgf manual - The CPU FAN_connector supports the CPU fan of maximum 1A (12W) fan power.
Edited by kisianik - 23 Dec 2014 at 4:55pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 5:05pm
3 pin fans can be hooked to a 4 pin header. They're pinned/keyed for correct hookup.
Looks good and stay in touch.
Psu fans are intake through the bottom and exhaust out the back.
Edited by bprat22 - 23 Dec 2014 at 5:07pm
  Quote kisianik Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 5:14pm
Thanks. But I will loose PWM control, that is bad, I realized already, so it is adding $99 DS board now, or look for 4 pin fans with extensions (most likely needed) later.
I think later is a good idea, just extra headache, or my fans will run at 100% RPM, that I already have in my present case, trying to make it more silent....
Too much headache, I will proceed now and get missing parts online, just wanted to avoid further customization....
Edited by kisianik - 23 Dec 2014 at 5:16pm
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 5:21pm
With any three pin fan on the motherboard, the fan optimizations in the ASUS Fan Xpert 2 can find the minimum operating voltage (the SP-120 fans on my computer can run down to 31% of max voltage) and slow their operation down using voltage regulation. The BIOS can also spin them down to 60%. PWM fans will allow the fans to operate down to around 20%, but not all is lost.
Edited by  - 23 Dec 2014 at 5:23pm
  Quote kisianik Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 5:41pm
Never dealt before with this situation, so I hope it will work as you said, that would be enough. Now I will need only 1 splitter (1 to 3) and 1 extension as AF140 have only 0.2A, and Asus Hero has case fan headers in the middle on the right side, between SATA and power connector.
Thanks for heads up, feel better now.
