Need help building 4k gaming pc buget is 3,800
Post Date: 2015-07-06
Coleligraphy View Drop Down
  Quote Coleligraphy Quote  Post ReplyReply bullet Topic: Need help building 4k gaming pc buget is 3,800
    Posted: 06 Jul 2015 at 8:11pm
Just would like some help.
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 06 Jul 2015 at 8:44pm
Configuration URL:
https://www.digitalstorm.com/configurator.asp?id=1236015
Chassis Model: Special Deal Hot Seller - Digital Storm Apollo
Motherboard: ASUS Z97-PRO (Intel Z97 Chipset) (Features 802.11ac Wi-Fi Connectivity)
System Memory: 16GB DDR3 1866MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
Optical Drive: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R)
Storage Set 1: 1x SSD (256GB Samsung 850 PRO)
Storage Set 2: 1x Storage (2TB Western Digital - Black Edition)
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 Ti 6GB (Includes PhysX)
Extreme Cooling: H20: Stage 2: Corsair H110i GT - 280mm Radiator Liquid CPU Cooler (Extreme Performance)
H20 Tube Color:- Not Applicable, I do not have a custom HydroLux liquid cooling system selected
Airflow Control: - No Thanks
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
  Quote Coleligraphy Quote  Post ReplyReply bullet Posted: 06 Jul 2015 at 8:51pm
Thank you. Will I be able to display over two monitors and upgrade later on ?. Or will a 4k tv with uhd be a good like a an acer 4k monitor. Really appreciate the help.
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 06 Jul 2015 at 9:03pm
Two monitors up to 1440p or a 4k TV or monitor will all work.  You won't be able to be 10-bit color out of the NVIDIA GPUs, though.
