Need help in upgrading PC
Post Date: 2018-11-14
Rakeshbhau View Drop Down
  Quote Rakeshbhau Quote  Post ReplyReply bullet Topic: Need help in upgrading PC
    Posted: 14 Nov 2018 at 11:16pm
[400-600]
[better multi tasking]
[i have vanquish 7 lvl 1 with gtx 1050ti(just bought it and its playable]
[i just need to know whats the next to upgrade to make my pc better at multi tasking(note: Newbee building on computer)]
[proccesor or motherboard i dont know. ]
thanks guys!
______________________________________________________________GoToMeeting IrfanView Town of Salem
Edited by Rakeshbhau - 16 Nov 2018 at 9:22am
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 15 Nov 2018 at 1:26am
More memory. Memory prices have been coming down as of late. Look for memory that is tested for compatibility with your processor (looks like probably an AMD). You can get memory sticks up to 16GB each; get a kit of two sticks (kits are matched). If you do indeed have an AMD, it will benefit the overall performance with higher memory speeds, so look for at least 3200 MHz and if reasonable/desirable go up to 3600-4000 MHz. After installation, you will need to go enable the XMP profile in the BIOS to increase the operating speed of the memory to that which it is rated at.
